VALISEN X10 TV Box - Amlogic S905W 2/16GB Android 7.1 2.4G WiFi 100Mbps VP9
    VALISEN X10 adopts 2017 new high cost-effective chip Amlogic S905W, comes with quad-core Cortex-A53 CPU up to 2GHz and Mali-450 MP GPU.
    High performance, high integration, low power consumption. It runs on the Android 7.1, which has good performance.
    You can connect to a world of content and entertainment at home.
    Smoothly watching TV shows, movies, browsing webpage and photos, and playing Android games with your family and friends.
    It is the best choice for you to have the smooth experience to watch the video or play games.
    Main Features:
    ● A full-4K high-performance SoC that supports H.265 video decoding up to 4K at 30fps
    ● 2GB DDR3 + 16GB eMMC, you can download whatever you like, keep them and enjoy them
    ● It runs on the Android 7.1, which is good to use. You can connect to a world of content and entertainment at home with the box
    ● A high performance of quad-core Cortex-A53 CPU can play a wide range of games
    ● Built-in 2.4G WiFi. Support IEEE 802.11 b/g/n. A more stable signal for you to enjoy higher quality video experience
    ● HDMI 2.0 is a faster way to send video and audio output to your TV
    ● Support 4K x 2K UHD video playing for a viewing experience
    Gearbest
    Lets have a close look at the VALISEN X10 TV Box - Amlogic S905W 2/16GB Android 7.1 2.4G WiFi 100Mbps VP9
    The Box
    Contents
    Ports
    Top removed
    PCB Removed
    More to come
      Moving along let's see what this one has to offer.
      Much the same as the others I can see but it's working ok.
      Startup good, WiFi and Ethernet working as expected
      Setup of Google, login no problems encounted and installing apps easy no funny business.
      The X10 does have Its own Ustore, TV Browser and TVMC like some other i have seen
      These that can be easily removed for a less intrusive experience if that is at all possible.
      UI and Installed apps
      When Removed you have invalid shortcuts/Icon that can give error when click main area.
      Easy Fix:
      Use another launcher and there is less problems and no junk, well maybe a little less or more pending on the launcher.
      System Information
      Ram and Storage Truth
      DRM Info L3
      CPU-Z 3 frames
      A1 SD Bench
      AIDA64 5 frames
      YT
      Much the same as other 905W.
      Looking ok for what it has to offer
      No Heat problems does as it should.
      A little Junk in the trunk easy removed.
      Thanks Gearbest:
        I have this tv box and stop on android logo! How to restore the factory setings?
          Thanks to Gearbest send me the restore image and now is working again!
          Στάλθηκε από το HT17 μου χρησιμοποιώντας Tapatalk
            does anyone have the Firmware for the Valisen x10? Thanks!
              Yes i have the firmware from gearbest. I have upload and send you the link.
                thanks Master , I will wait for the link
                  This is the link for the firmware
                  To use Google Drive, you need to use a supported web browser. Learn what a browser is, which browser you use, and how to update to the latest version. Option 1: Find the update for your browser To
                    thank you very very much. Everything worked out great
                      I am happy to help.
