ZX918 RK3328 Android 7.1 2/16GB Dual Wifi Fast Lan BT4 USB 3.0
ID:	694761Click image for larger version
    ZX918 RK3328 TV Box
    ZX918 is a good choice for you to have the smooth experience to watch the video or play games,
    Equipped with RK3328 quad-core ARM Cortex-A53 CPU. With 2GB DDR3 + 16GB eMMC,
    4K resolution enables you to feel the most high-definition video! Support Miracast / DLNA / Airplay, share your video to your TV.
    Main Features:
    ● It is lighter than a phone
    ● The most advanced processor RK3328, which comes with 64-bit Cortex A53 and Mali-450 GPU
    ● It runs on the Android 7.1, which is stable to use. You can connect to a world of content and entertainment at home with the box
    ● 4K VP9 can help you save 50 percent bandwidth resource, and deliver razor-sharp detail and vibrant images
    ● Bluetooth 4.0 connectivity. Easy pairing with most Bluetooth-enabled devices
    ● HDMI 2.0 is a faster way to send video and audio output to your TV
    Gearbest
    Thanks again to Gearbest we can have a look at the ZX918 RK3328 Android 7.1 2/16GB Dual Wifi Fast Lan BT4 USB 3.0
    Another on of these small units to tuck away..
    Lets have a look
    The Box
    What's in the Box, A green remote don't think i have one that colour.
    Ports
    Remove the Underside, not much to see
    Remove PCB
    Gearbest
    Small and neat lets see what it has to offer later
      I have a R-tv mini+ 2gb/ 16gb with exactly the same board. the only diff is the sticker said A5x mini on it. I couldn't find the firmware for it so I'm running A5x pro firmware. Thanks again to thenyboy for the assist. I would love to try this firmware on my mini+.
        Hoping this would maybe have something different but appears much same as others, except the remote
        Does the job, gets a bit warm, Rom also is a little dated and could do with an Update.
        Google setup all good, installed apps easy, WiFi Good, Ethernet OK and BT does the BT thing as it should.
        Has Root no SU and no Upper or Lower Bars
        Green remote works well.
        UI and Installed apps
        System Information
        Drm
        Antutu:
        Running a little warm when pushed, some test can be extreme and not normal daily use
        Ram and Storage Truth
        CPU-Z 3-frames
        A1SD Bench
        Geekbench: CPU more info >>> http://browser.geekbench.com/v4/cpu/5506485
        Geekbench Compute
        AIDA-64 7-frames
        We can hope for a better Rom maybe
        Heat will be its only downfall,
        Like all test just to give an idea of how it performs and what its got
        Does the job.
        Thanks Gearbest
