CS918 HFW 1.2.0 1080p - H264 stream decoding problem
    I'm owner of this very interesting tv-box. My main concern is about a video stream decoding. I want to stream from my computer dvb card a 1920*1080 i 11 Mbits/sec H264 + AC3 . They're both connected with ethernet.
    Streaming works on another PC even on Wifi, it also works on my smartphone Huawei ascend P2 with Vplayer on Wifi !!
    I tried all applications on CS918 with no success :
    Mxplayer with correct version (found on geekbuying) => laggy on HW and HW+ decoding
    Vplayer => crash when activating HW decoding
    VLC => crash when activatiing HW decoding
    BSplayer => laggy with HW decoding
    Of course all of these are very laggy with software decoding.
    See here stream info
    Any ideas or suggestion ?
    hmm...
    Are you stating..
    it worked before.. but after updating to 1080kernel nolonger? (title post)
    have you tried a recording a bit.. then move it too the cs918.. the play it
    to see if its a file/codec issue or not
    then do a speed test.. to see if thats the issue
    How does 720 do?
    on a personal note...
    How does this new firmware perform/feel?
      Originally posted by mitchell4you View Post
      hmm...
      Are you stating..
      How does 720 do?
      No it didn't work with original kernel same apps.
      Good idea, i will try the recording ,then local playing.
      I haven't tried the 720 firmware but i don't think it's a firmware concern, it seems to be incompatibility between RK3188 and hardware decoding..
      This firmware seems fine, not bullshit installed . Playing mkv stored on my nas through network works fine, even 1080p ...
      I will update later today.
        Well, humm, after Mxplayer updated by itself, local playing of recorded file was fine. It's still laggy / crashing with all other players.
        I tried again the streaming and WTF !! it's working fine also ! Still have a desynch issue between sound and pictures but it's smooth and sharp picture.. i'll continue investigating for the resynch of sound.
