H96 Pro+ or Alfawise H96 Pro+
    Hi Guys, i want to buy this device but got a little confused.
    There are two options when i search for "H96 Pro Plus".
    One is the
    Alfawise H96 Pro Plus
    and the other is
    H96 Pro Plus (Instead of the Alfawise Logo - it has 4K Logo)
    Please see the link.
    Which one is the correct Pro Plus ? When i compare the specs - it is all the same.
    Which one shall i buy ?
    Thanks in advance folks.
    Best Regards.
    Just US$82.46 + free shipping, buy H96 Pro+ TV Box Android 7.1 online shopping at GearBest.com.
    Both are. Check the feedback of the one without Alfawise logo. There are picture with logo. Dont know why they sell 2 "different" Boxes, tho.
    And even if You get without logo, than it will still be Alfawise one. There are some without the logo... don't know why...
    ZUK Z2 Pro ✓ᵛᵉʳᶦᶠᶦᵉᵈ
    ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
      Hi @ch3mn3y,
      Thanks for the prompt answer. As i read here - there are two types of boards inside the unit. Blue and Green ones - with v.4, v.5, v.6 and so on.
      Could you please assist me which one i shall buy - so i have the possibility to update the unit with no problems?
      In general - could you please post me some info what exactly i shall check - before buying the device ?
      Thanks in advance for the great support.
      I really appreciate it.
      Best Regards.
        Unfortunatelly You'll never know which board You will get.
        However it seems that now there is huge chance to get V6 when buying on GearBest.
          I just placed my order for
          Alfawise H96 Pro+ TV Box 3GB RAM + 64GB ROM
          I noticed that when i change the RAM and ROM options in the GearBest site - the photo changes from the Alfawise to the 4K Logo. So i think this is the same device.
          So - i am waiting now for the 3GB Ram and 64GB Rom to arrive :-)
            simichoil
            Good choice. I really love this Box, especially with superceleron's Rom
