Advice on Box with good FW update support?
    I am planning to turn a 40in 4K TV with a touch bezel into a giant tablet...
    (4k because... when u stand in arms-length of a 40inch, a fullHD screen is quite pixellated...)
    For that, i am looking for an android box that will have the longest possible firmware updates. (Security-fixes).
    So my research has lead me here.
    Can a certain manufacturer be recommended for that, or a specific box, or a chipset?
    I would expect the favorite of you fw-hackers might be a good choice?
    My other consideration would be a raspberry- alternative such as the asus tinker board.
    Which way would you go?
    Hi ,
    the most chinese Companys are doing nothing , only a few support updates , more or less ,
    like Ugoos / Zidoo ... , Amilogic are the most sold Boxes , you can see it here , too .
    Yesterday i found this :
    Hope you can make the best choise for your needs / greetings gefattern
      Buy the Nvidia shield,nothing better or as fast! You can get them for 149.00
        gefattern, thanks... So u say amilogic would be solid in terms of updates, or just hw quality?
        ​​​​@palerider, shield runs android TV, not a full android, as far as I know...
          Hi ,
          AML is only the PCB Maker , not the Box Maker / Seller , most of the Companys making no Updates , better to look for a
          Box with good Developer support , or Shield good Quality and Specs , Updates too i think ???
          greetings / gefattern
