MXQ PRO 4K RK3229 after firmware restore box won't boot
Originally posted by Mike1832 View Post
I see. How would you unbrick it? I can't even connect the box to the pc anymore.
Originally posted by DS-1 View Post
Write and post the image here too: http://freaktab.com/forum/main-categ...location/page4
Finally I found a firmware which seems to run fine. Inclusive WiFi. You mentioned that you own the same box. I isnatlled this firmware:
Download here: http://www.filefactory.com/file/4n7u...0170308_r1.rar
After the install, it tooks about 5 minutes till the box installed all apps. This is Android 5.1.1 Originally 6.0.1 was installed. That's ok for me. The box is even faster than it was wit 6.0.1.
I really help this helps you too.
Now I have to figure out how to root this beast. I only want to use the box as a Samba server. May be someone have a hint. Last time I tried Kingroot (or Rootking?), but that didn't work.
Originally posted by vendaspe View Post
The firmware I installed had the issue, that the box freezes after a few minutes when I did the box leave alone. But when I play around, go into menus, download apps and so on, the box works fine. It seems some power safer function causes this issue. I disabled already lock-sreen, screensaver... Any ideas?
Now I installed the firmware you mentioned. But it ends up with a green screen.
I'm thankful for every idea.
There are currently 3503 users online. 0 members and 3503 guests.
