If you need pinch to zoom and you have another portable Android device, I recommend you to use Droidmote. The app also supports touchscreen emulation. This is very helpfull for games without mouse support (The Room, Deadtrigger 2, Giana Sisters...). Without it you can't do anything in those games.
Anyone using a Logitech K400
I have the K400 too, but I use it together with a mouse (Logitech M525). Both are working fine together with only one Unifying dongle.
Originally posted by hispan1c View PostI just looked on the back and it says K400r not sure if the different model number has something to do with it.
..........................................k400.... .............................................. k400r
Touchpad supported gestures - Left Click (Tap-to-Click)
- Double-tap-and-drag
- Vertical Scroll
- Right Click
- Vertical Scroll
- Horizontal Scroll
- Zoom
- Windows 8 Edge gestures
Originally posted by rivol View PostMine is also the K400r.
How do you zoom in or out, the touch pad doesn't zooming with X7
Is there any other key combination that can do it ?
AW: Anyone using a Logitech K400
Originally posted by neomode View PostTry TinCore great app to play games with keyboard and mouse.
Neomode
Send from Mobile
But how can I keep the default behaviour of the mouse wheel, while I'm in touch hybrid mode.
When I map it to mouse click/default, it will do nothing, when I want to scroll.
Gesendet von meinem LG-P710 mit Tapatalk
Originally posted by rivol View PostAccidentally I found out that K-400 with double-tapping its zooming in/out when browsing or using maps
anyone came up with reducing the sensitivity for multi-touch features? i dont know if you can actually call it "multi" anyway.
two-finger scrolling seems fine for most, it's a pain in the butt here. while trying to scroll, it wont move initially, then after you give it a bit of speed, it overscrolls, it's quite hard to find the balance
then homescreen two-finger scroll, you have to do it vertically for moving around a horizontal page, very sensitive here as well.
F5 wont refresh, right-click is BACK (very annoying)
i found out, holding both left and right click pops up the known ADD to home screen feature.
Originally posted by rivol View PostYes that's right, better than nothing
With the maps is always zoom in and in and in, maybe one day will find how to zoom out
at least this works on my note 2
sry for my bad english... it´s been a long time that i´ve being in school... ;-)
Guest
Re: Anyone using a Logitech K400
Originally posted by droopy1979 View PostDo a double Tap, but hold the 2nd tap. then move your finger down. (when you move your finger up the zoom goes back in)
sry for my bad english... it´s been a long time that i´ve being in school... ;-))
There are currently 4163 users online. 0 members and 4163 guests.
