I have an android box Amlogic S805. The system is stuck on booting, when i turn on the box i get only booting logo and nothing happens after that. I have tried hard rest by pressing the back bottom but nothing happened also. I have tried to connect the device to windows PC by using USB Burning Tools application but my PC doesn't detect the android device. Any one can help please?
S805 tv box stuck on booting logo
Hello guys.
I have an android box Amlogic S805. The system is stuck on booting, when i turn on the box i get only booting logo and nothing happens after that. I have tried hard rest by pressing the back bottom but nothing happened also. I have tried to connect the device to windows PC by using USB Burning Tools application but my PC doesn't detect the android device. Any one can help please?Tags: None
here is something that can help you, click on link below and just,
follow the video tutorial
http://mxqproject.com/tutorial-amlogic-burn-card-maker-tutorial-short-pin-method/
also you need sd card max 8gb, not above, formated in fat32
There are currently 4870 users online. 1 members and 4869 guests.
