Brand: Ugoos Core: Quad Core CPU: Cortex A53 GPU: Mali-450MP2 Max. Extended Capacity: TF card up to 32GB (not included) RAM: 2G RAM RAM Type: DDR4 ROM: 16G ROM System: Android 7.1 Type: TV Dongle Processor: RK3328 TV Box Features: 5G WiFi,Gaming |
Audio format: AAC,APE,FLAC,M4A,MP3,OGA,OGG,WAV,WMA Decoder Format: H.265 Photo Format: BMP,GIF,JPEG,JPG,PNG Video format: 4K,AVS,H.263,H.264,H.265,MPEG1,MPEG2,MPEG4,MVC,RV, VC-1,VP8,VP9 |
Antenna: Yes Bluetooth: Bluetooth4.0 Interface: AV,DC 5V,HDMI,IR,OTG,TF card,USB3.0 Language: Chinese,English Other Functions: DLNA Power Supply: Charge Adapter 5G WiFi: Yes WIFI: 802.11 b/g/n/ac HDMI Version: 2.0 |
Power Type: External Power Adapter Mode |
Package size (L x W x H): 16.00 x 11.00 x 10.00 cm / 6.3 x 4.33 x 3.94 inches Package weight: 0.4600 kg Product size (L x W x H): 10.50 x 7.00 x 1.50 cm / 4.13 x 2.76 x 0.59 inches Product weight: 0.0640 kg |
Package Contents: 1 x TV Dongle, 1 x English User Manual, 1 x Power Adapter, 1 x HDMI Cable, 1 x IR Remote Controller, 1 x Antenna, 1 x DC Cable, 1 x USB Cable |
Ugoos UM4 TV Dongle - RK3328 Android 7.1 / 2GB DDR4 RAM + 16GB Dual WiFi USB3.0 / BT4.0
GearbestLast edited by trebor; 02 May 2018, 07:58.Tags: None
Thanks To Gearbest today we can have look at the UGOOS UM4 TV Dongle - RK3328 Android 7.1 / 2GB DDR4 RAM + 16GB Dual WiFi USB3.0 / BT4.0
Great to be able to see a and use a quality looking Unit after the last lot of units we have looked
As you will see has it all, and always good support from UGOOS (sometimes times you have to wait a little) But good things come to those who wait
Lets Have a look see
The Box
Whats in the Box, IR extender, USB OTG, 5VDC 2.5Amp Power supply all here and looks great
Ports
Base
Finally remove the Lid and looking good. RTC battery by the looks
GearbestLast edited by trebor; 22 December 2017, 06:03.
To continue with this little box of joy and heat when pushed
When I saw what it had on the inside, had that feeling like other Rk3328
You will see the numbers later.
All Ugoos have lots of features to be had in settings as you will see
A simple Launcher3 UI installed at present
Install Microsoft Launcher working good...
The Setup was easy, Google account easy and WiFi also good.
Apps installed appears zippy for sure
I think this type of CPU running 1080 with 64bit...needs some cooling as other 3328 have shown
In saying that these temps are reached when extreme number crunching is happening so daily use, videos, games Internet should not be a problem
Remote with extender works well.
Let's have a look
UI Launcher3 and system showing Settings 8 frames about 4 seconds a frame
Shut Down Options
Ram and Storage Truth
DRM Info L3
AIDA64 8 frames used some cooling
Geekbench CPU, No cooling in these tests
Geekbench Compute
A1 SDBench
Internal Player No trouble played it all, Random snaps all Good with cooling 18 frames 2 second delay.
The Images that lack of Contrast was just screencap, on TV all colours good.
MS Launcher
Not many apps installed as can be seem will give FTMC and others a whirl soon
Gearbest
There are currently 1927 users online. 0 members and 1927 guests.
