Brand: MINIX CPU: Apollo Lake N4200 Core: Quad Core GPU: Intel HD Graphics 505 Max. Extended Capacity: 128G |
Decoder Format: H.263,H.264,H.265,HD MPEG4 Video format: 4K,DAT,H.263,H.264,ISO,MKV,MPEG,MPEG-1,MPEG-4,MPEG2,WMV Audio format: AAC,APE,FLAC,MP3,OGG,RM,WMA Photo Format: GIF,JPEG,JPG,PNG Support 5.1 Surround Sound Output: No |
5G WiFi: Yes Bluetooth: Bluetooth 4.1 + EDR Power Supply: Charge Adapter Interface: DC Power Port,HDMI,Kensington Lock,Mini DP,RJ45,SPDIF,USB3.0 Antenna: No Camera: Without Language: English,Germany,Italian,Japanese,Simplified Chinese HDMI Version: 1.4 Other Functions: 3D Games,3D Video,DLNA,Miracast,NTSC,PAL HDMI Function: CEC,HDCP,HEC Power Consumption.: 12W RJ45 Port Speed: 1000M |
System Bit: 64Bit WiFi Chip: Intel3168 |
Power Type: External Power Adapter Mode |
Product weight: 0.4120 kg Package weight: 1.1130 kg Package size (L x W x H): 25.00 x 18.00 x 10.00 cm / 9.84 x 7.09 x 3.94 inches |
Package Contents: 1 x Mini PC, 1 x EU Charger, 1 x US Charger, 1 x UK Charger, 1 x English User Manual |
MINIX NEO N42C - 4 Intel Apollo Lake N4200 Mini PC - 4GB RAM + 32GB ROM
Specification
GearbestTags: None
Bit of deal happening at Gearbest:
MINIX NEO N42C - 4 Intel Apollo Lake N4200 Mini PC - 4GB RAM + 32GB ROM BLACK
Coupon: GBCPNW 15% OFF $258.40
Valid till 2018/02/28
http://freaktab.com/forum/advertiser...775#post705775
Let's have a look today at the MINIX NEO N42C - 4 Intel Apollo Lake N4200 Mini PC - 4GB RAM + 32GB ROM BLACK
As always thanks to Gearbest for the show and tell.....
This should be good as Minix stuff is normally the Bee's Knees.
Let's have a looks see at what you get
A Huge Box
Peek Inside
More Goodies
What we have: Vesa Mount, Beefy Power supply and fitting, Spare screws, Standoff and SPIDF converter to 3.5mm, and feet
Bit of a Look around, Plenty of Ports, DP, USB C, HDMI...lots
Remove Base, installed with 4GB, as I have a another 4GB I will it to 8 GB
Up Close: RTC battery, M2 Slot, Wifi Chip and Ram
Removed PCB fan cant stay this time Chip and ram all look the same
More to come as we fir it up and test it out
Startup was pretty good, (easy) with the typical Windows OBE so just agree and let it do it I found.
Set up the Locale and region, a few updates, restarts and with in an hour or so all up to date.
With only 3GB left on C drive by the time all was done, a system cleanup removed old windows etc and was able to reclaim some space
When running these limited space as in 2gb or 4gb just keep an eye on things don't junk it and it will do the job.
Performance is looking good, WiFi and Ethernet as expected (excellent)
Don't have a M2 to slip in at this stage will see what I can find in the second hand market.
Found a 256GB 100bills or so might have it in a couple of days.
Cooling is excellent, Fan was not noticed, even under stress, that is good.
Intel Pentium Mini PC with Windows 10 Pro (64-bit)
Ideal Solution for Industrial + Commercial Applications. + SOHO
As seen VESA Mount included for fast and easy installation.
Fully Functional, Customisable Mini PC with Windows 10 Pro (64-bit) Pre-installed.
NEO N42C-4 delivers all the power and functionality of a desktop computer in a compact, stylish chassis.
Powered by Intel N4200 processor with integrated Intel HD Graphics 505, NEO N42C-4 is ideal for industrial and commercial applications; Digital Signage, POS and Thin Client solution.
Its sleek and understated design allows for easy integration in any places with limited space, while still achieving premium, ultra-responsive performance and the power to fulfil your productivity needs. Pre-installed with Windows 10 Pro (64-bit), set up is effortless and NEO N42C-4 is ready to run straight out of the box.
Ultra-High Definition 4K @ 60Hz & Triple-Display Ready.
Thanks to its Intel HD Graphics GPU engine, NEO N42C-4 excels at producing super detailed, crystal-clear 4K @ 60Hz imagery; capable of streaming Ultra-High Definition vibrant visuals smoothly.
NEO N42C-4 is Triple-Display Ready, allowing easy connection for up to three displays via the HDMI, Mini DisplayPort and USB-C outputs. [Important Note: The integrated USB-C port only supports video output, not audio output].
Expandable, Flexible Design.
NEO N42C-4 comes with 32GB eMMC internal storage and 4GB of DDR3L, while the inclusion of a 2280 M.2 slot [SATA 6.0Gbps] and a pair of SODIMM slots [dual channel support] offer the flexibility to expand the storage and RAM to meet user’s requirements.
The 2280 M.2 slot [SATA 6.0Gbps] provides storage expansion up to 512GB, and the pair of SODIMM slots support up to 8GB of DDR3L memory each.
Packed with Connectivity; Integrated USB-C Port.
NEO N42C-4 is equipped with a vast array of connectivity options: Three USB 3.0 Ports, HDMI [4K @ 30Hz], Mini DisplayPort [4K @ 60Hz], USB-C [4K @ 60Hz], Optical S/PDIF, 3.5mm Audio Jack, 802.11ac Dual-Band Wi-Fi, Gigabit Ethernet and Bluetooth 4.1. [Important Note: An active adapter is required to convert Mini DisplayPort output to HDMI/DVI output].
The integrated USB-C port supports ultra-fast data transfer, video display output up to 4K @ 60Hz and simultaneous power input. [Important Note: USB-C power input is optional, standard DC 12V, 3A power adapter included].
Minimal Noise, Zero Disturbance.
NEO N42C-4 employs an active cooling solution to ensure safe operation and stable performance even throughout prolonged operation, while producing absolute minimal noise to guarantee zero disturbance during usage.
The chassis also incorporates cleverly designed ventilation and air holes to maximize airflow, and maintain appropriate temperature to safeguard against over-heating.
Friendly Features.
Built in accordance to industrial standards, NEO N42C-4 is highly reliable throughout periods of continuous 24/7 operation.
An auto power-on option can be enabled within the BIOS menu settings, removing the need to manually power back on after a power outage.
NEO N42C-4 includes a VESA mount for easy installation on the back of a VESA compatible TV or monitor, no tools are required for mounting once the included bracket has been installed.
The VESA mount gives full access to all ports and power button, and does not affect the Wi-Fi or Bluetooth performance; Eliminating the cable clutter of a traditional office setup.
On to a bit of system Information and some tests with the MINIX NEO N42C - 4 Intel Apollo Lake N4200 Mini PC - 4GB RAM + 32GB
All Good and Activated
What's making it all Happen, Device Manager
Bit of Stress that really did not do much stress at all
PerformanceTest
Another View >> https://www.passmark.com/baselines/V...id=97278611517
GeekBench
Compute
Full Details >> https://browser.geekbench.com/v4/compute/1972237
CPU
Full Detail >> https://browser.geekbench.com/v4/cpu/6915243
C Drive got a little full after all the updateing
System clean found what we needed after a good clean.
Wifi and EtherNet Level Pegging to day
Some File Copying
CrystalDiskmark V6 from App Store
CrystalDiskmark V5.1.2
XS Bench Score
Not a high powered device as we know
All done in small steps
From many moons ago with the first Intel Atom to now and forward
All have there place in this world.
Linux can also go on with a bit of a Fiddle...
Excellent review over at CNXSoft, by Ian W MORRISON (Linuxium)
Setting up Linux on the MINIX NEO N42C - 4 Intel Apollo Lake N4200 Mini PC - 4GB RAM + 32GB ROM BLACK for those interested
Also A video by Roberto Jorge showing some feature of Three Monitors Display and bits
Also reading around it is possible to install win10 pro on the M 2, just need some Bios Adjustments to make it so..
More happening,
Did a heap of Netflix, easy as, Plex does most as expected...so looking good there as expected.
Time to upgrade to a M2 Drive...(arrived this day) easy and painless
M2 Installed and you can see the other 4gb Module
So with the drive installed booted back into Windows.....to check it out all good Toshiba 256GB
Installed Minitool Partition wizard (free Version)
Selected Migrate OS to SSD/HD
Option B to keep original (32GB eMMc) in computer (just in case we need to go back)
Ask for Destination being New M2 Drive.
And away it went copied most over
Towards the end It advises we can't copy C: drive cause its in use, Reboot and MiniTool will do the rest Automatically...sounds good to me
Rebooted MiniTool started in a Dos like Mode Copied C drive from eMMC to New M2 about 40 seconds or so
When Done rebooted, I dropped to Cmos turned Off eMMC drive and the rest is history so far all seems OK
All working no need to start fresh so far, but anything is possible,
Not sure as yet why the D: System showed up it part of the M2 I can't do anything with so its safe.
Windows has Activated OK,
Will see how it goes, I always expect the unexpected with Windows, may have to re setup if it goes Belly Up but so far All good.
Little more speed than the Internal eMMC
and not to forget
There are currently 1526 users online. 1 members and 1525 guests.
