Problem with TV BOX H96 PRO Plus Amlogic S912 Octa core Android 7.1
I bought TV box H96 pro plus and we are using this box one month. After one month it doesn´t work. Unfortunately I don´t know why. When I tried to launch box on the TV and switched source for this box, there are only black screen with no signal. Box are ON (blue LED light burns), but it´s not possible to switch OFF, it´s not possible reset box, and also different cable doesn´t work. Do you have any tip for solution? I can try to make complaint, but it´s bought through **** from china. Thanks for tips!Tags: None
Originally posted by do_poctu View PostI bought TV box H96 pro plus and we are using this box one month. After one month it doesn´t work. Unfortunately I don´t know why. When I tried to launch box on the TV and switched source for this box, there are only black screen with no signal. Box are ON (blue LED light burns), but it´s not possible to switch OFF, it´s not possible reset box, and also different cable doesn´t work. Do you have any tip for solution? I can try to make complaint, but it´s bought through **** from china. Thanks for tips!
think you have the same Problems like other H96Pro+ Users here , u must flash new ,
but important to know are the Specs for the right Rom , Wifichip , DDR Chip .... , please
read first some of the H96Pro+ Threads for more Infos , small Hint a better Powersupply
helps , 5V / 3000mah is okay .
greetings / gefattern
Thanks a lot! I thought that it´s destroyed.
Maybe one more question - how can I find out if I have 5V/3000mah?
Currently I can see on the charger + blackbox these information:
Charger:
- AC/DC adapter
- Model: JKX-912
- Input: 110-240V AC, 50/60Hz 0,3A
- Output: 5V DC 2A
Blackbox:
- CPU: S912
- RAM: 3GB
- OS: Android 7.1
- ROM: 32GB
Anyway, I have one more question - is it neccessary to make flash through MMC card or is it possible to do it through USB port? Is it possible to do it without any signal?
I tried all hdmi ports, also different cable and different TV.
its out of my mind that it doesnt work 3 weeks after first using device. I didnt do any change of device (no root, no flash).
Okay then, I will try to find correct version of android and will try to make new flash.
Two other questions:
1. Is it possible to make flash through USB or is it neccesarry microsd card?
2. Is it the same version of android like before or its different one?
Thanks a lot for all hints and your posts. Its very helpful.
Hello again,
I connected my H96 pro plus with PC via USB cable and tried to connect device (through Amlogic USB burning tool 2.0.9) - there´s error message "Get key failed". What happens, please?
Edit: aha, it´s bad file, I guess.
But I have no signal when I plug the HDMI to the TV. Maybe it´s problem with this: https://www.youtube.com/watch?v=BL05PrgvO0E
What do you think?Last edited by do_poctu; 03 January 2018, 21:02.
What do you think?
casue I have the same issue. Mine only worked for 2 days
Originally posted by maxim33 View Posthallo, leave all things apart, at first just get a new 5vot 3amp power adopter and most probablly all of your problems gone, in 99%cases it is the bad power adopter, so just try with a new one and you did not need to flash or format your box.
i think you are right , but a good supported CustomRom , like the one of the
great Dev. Superceleron can make this Box much better .
But if you want to try , remember the two different PCB types green/blue and
needed Roms !!!
There are currently 1249 users online. 0 members and 1249 guests.
