- Hallo, everybody,if you are suffering with that prblem, no boot no display only blue led blinking. and tried hundreds of times and always stuck at 2% in usb burning tool. Than you should follow that procedure and will be sucseded. At first i have powered the box with a power bank on the usb port just alongside the sd card slot and used aml_7.1.2_s912_q9377-H96PROPLUS_LP_KDMC_mac-20171010( As in my case my box has Blue pcb S32V5 ). burning process completed in first try. So you must try that procedure:-- 1.-at first disconnect your network connection. 2.-turn off your antivirus program. 3.-open USB Burning Tool 2.0.8 and change language to english . 4.-select firmware image and tick "erase flash " and "erase bootloader " boxes .( with normal erase) 5.-power up you box with a power bank at the usb port alongside sd card slot (for that, you have to open the box) . 6.- now connect the other usb A to A cable to your pcand the other end to usb slot near power port on box. 7.- check if box is detected by pc or not (use USBDview , it will show all conected usb devices) 8.-if box is not connected try shuffling usb port. when connected it will shown as WORLDCUP DEVICE. 9.-now it will also be shown in usb burning tool in device id as "HUB5-4 "or else numbers after word HUB. 10.-now in usb burning tool push start button and process will be started and no stuckung at 2% or 4% ,it will take some time after reaching 95% or 98% ,and in few seconds it get completed. 11.-push stop button and unplug usb cable and you have done !!! i think it may be helpffull to all of those suffering burn failure erorr at 2% and 4%.
tips for sucsessfully burning with USB Burning Tool
Tags: None
There are currently 3133 users online. 0 members and 3133 guests.
