TWRP for H96 Pro Plus ?
    Hey,
    I searched the forum and found this: http://freaktab.com/forum/tv-player-...mlogic-devices
    But the q9377 is not listed in the supported devices, does anyone knows where i could find one to backup my rom before installing a custom one ?
    H87 or H96?
    Coz there is TWRP for the latter and it works fine.
    ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
      H96 my bad, after doing more research i found this img
      Ty
        Use this: https://mega.nz/#!Ji4iEAjI!5iCbS2F9J...cO6-MWb1b-z90I
        It's newer (3.1.1-0, one from Your post is 3.0.2-0). And it's built for our Box I think.
        I took it from superceleron's "Normal" Rom and used it before flashing his Rom. No problem with stock on S32-V6 H96.
          tribes and ch3mn3y  I have tried both these images.
          But when I boot using these Images, (while pressing the button), H96 Logo appears and the systems just stucks there. Nothing happens next.
          I have q9377. What can be the issue.
            Originally posted by areeb View Post
            tribesÂ*and ch3mn3yÂ* I have tried both these images.
            I have q9377. What can be the issue.Â*
            i have the same Issue, did you fix it?
              TWRP for H96Pro Plus
              1. Install Flashify
              2. Click "Recovery image" and then "Choose a file"
              3. Find "Recovery.img" and click on it.
              4. Click "Yup!" and then "Reboot now"
              Box is restarted and you have TWRP.
              Flashify
              Recovery.img
                great it works.. thx
                  I am searching for a TWRP img file but link is dead.
                  Anyone could reupload these files please?
                  1. Install Flashify
                  Flashify
                  https://drive.google.com/open?id=1RD...oiEn_c07RV8z7i
                  Recovery.img
                  https://drive.google.com/open?id=1Ji...2N13kXzIQ0Xthl
                    Ditto ............Please.. Anyone ?
                    Thank you.
                      Thank you.
                      TWRP Tutorial and downloads:
                      Today we present a guide to run TWRP (Team Win Recovery Project) on our Android TV-Box with Amlogic S905, S905X, S912 or S905X2 SoC. A system that allows us
                        Really appreciate the Heads up Mate!.......Big thanks.
                        Best Regards,
                          Thank you very much
