H96+ Pro Plus Original Rom Was Not Found (ZH-01-S912-TVBOX-V.3.0)
I asked the H96+ Pro Plus TV box to do a supersu update. I confirmed the review. The TV box was turned off and turned on again. Make your life stuck in the colorful logos. I installed a lot of software but it did not work stable. I communicated with Hcygood manufacturer. Unfortunately, they did not help to reach the original stock rom of the device.You may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosLast edited by akrep6; 01 January 2018, 21:59.Tags: None
Hmm. I would advice You to try restore my TWRP backup. I have S32-V6 Box, but it worked wit Wisdom one, which is totally different. So way it shouldn't work with Yours?
Other than that I don;t think there is firmware for this version of the H96 Pro+.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostHmm. I would advice You to try restore my TWRP backup. I have S32-V6 Box, but it worked wit Wisdom one, which is totally different. So way it shouldn't work with Yours?
Copy TWRP folder to Your devices memory or to SDcard, than check if something is available under Restore button. If yes, than restore it, if not than go to Backup, start backing up anything and cancel it. Go back to memory/sdcard and copy folder from TWRP/BACKUPS/q20x/ to TWRP/BACKUPS.<Your_folder_name>/.
As for matching Your device I can say that I don;t thnik so. It's backup of stock 7.1.2 with may build date from my S32-V6 H96 Pro Plus. However at the beggining (nobody with V6 wrote on the forum) I thought that I have Wisdom Box and someone else with already bricked Box used my backup on his Wisdom H96 and it worked again.
I think that firmware, nor kernel, are not the biggest problem here. Just the bootloader. And if Your is fine, than restoring working backup may help.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostCopy TWRP folder to Your devices memory or to SDcard, than check if something is available under Restore button. If yes, than restore it, if not than go to Backup, start backing up anything and cancel it. Go back to memory/sdcard and copy folder from TWRP/BACKUPS/q20x/ to TWRP/BACKUPS.<Your_folder_name>/.
this only works when his Box has a TWRP installed , otherwise no chance to restore ,
what about flashing one of the Superceleron Roms for this Box ???
greetings / gefattern
Hi ,
Hi ,
Originally posted by akrep6 View Post
I tried to install the Superceleron firmware. I tried it with the burning tools installer. I tried with a card reader program. I printed the files on the card. After the installation starts, the screen is green until the installation is complete. Superceleron does not accept firmware in the tv box. I have tried all versions of the Superceleron, maybe it accepts the TV box, maybe not.
i am not sure , but maybe you can install the GT1 Rom , but the Specs must be similar , otherwise no luck ,
did you ask in the Superceleron Thread for Infos ??? , better than always making a new post , i know that
others had this Bug , too .
Did you bought the Box new , or is it a little bit older version of PCB , do you know the PCB Number ???
Hi ,
greetings / gefatternYou may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
After the update of the SuperSu program, the TV box was left bootloop. I tried installing many software with the USB box burning tool. Some of the software on the link that Shonk gave in the forum was uploaded to the tv box. But the device is not working well. After a while the device is turning back on the opening logos. Even if TWRP is installed on the device, the original 7.1.1 firmware that came on the device will not come back. Because other firmware was loaded in the memory. Why does not the manufacturer support the products it produces after the sale? That's the whole point. Producer solves the problem of granting the software on the date the firm created the tv box. The device is already rooted. Updating is not my mistake. I made a lot of correspondence with Hcygood. They said they would send the software for the device. Then they do not even answer me e-mail. Customer satisfaction is not important? I also searched on the internet, in the forums. There are consumers who have TV box 'ZH-01-S912-TVBOX-V 3.0' version. The manufacturer should solve these problems. It's that simple.
Best regards...
akrep6
I believe that manufacturer (Alfawise) is supporting all versions of the Box. However images are not available for everybody. Sellers should have access to them, but tehy already sold the item, so why should they do something more? Some of them try to help, true, but some of them don't.
Maybe try to contact Alfawise for image? If the seller is not responding, than higher instance may help?ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
I think there was a misunderstanding. I bring clarity to the subject. Thank you for the opportunity, my friend. The tv box I bought is not Alfawise. Alfawise gives its customers all kinds of support. There is no doubt about it. I direct my criticism to the Hcygood representatives of the manufacturer. In our daily life we are all shopping. Before shopping, we investigate, we take the positive opinions about the product and decide to buy the product. Tv boxes are also good. The problem is the customer representatives employed by the manufacturer. If you are a manufacturer, a customer has bought the product you are producing and you have a problem, you are obliged to solve the problem of the customer. As a result, the vendor could not find a solution and reached the manufacturer. I emailed the Hcygood sales manager with photos of the green board for the TV box. He directed a specialist to solve Konuyu. We communicated with Expert and Whatsapp. He said that he would send original software belonging to the box. The promise he gave the next day did not hold. The solution is a very simple software issue.
GreetingsYou may only view thumbnails in this gallery. This gallery has 5 photos.5 Photos
Getting working twrp even on supported devices an issue as some break firmware. You can bitch write and copy the whole world on your firmware issue. I' suggest identifyng the Wi-Fi and seeing other firmware already out that will work on the device. From quick look SC firmware should work on it and provide you with more fixes then found in a stock knock off device. Some set backs may be remote doesn' work ect. But simple mouse can solve those issues. Or wait till a knock off device maker makes release of software they most likey copied from another.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostGetting working twrp even on supported devices an issue as some break firmware. You can bitch write and copy the whole world on your firmware issue. I' suggest identifyng the Wi-Fi and seeing other firmware already out that will work on the device. From quick look SC firmware should work on it and provide you with more fixes then found in a stock knock off device. Some set backs may be remote doesn' work ect. But simple mouse can solve those issues. Or wait till a knock off device maker makes release of software they most likey copied from another.
Let's just wait a little more. It would be better if there was a solution. If the problem is not resolved, the TV box becomes garbage. Hcygood sales manager Joyce Lin gesture can surprise me. Maybe a new TV box is a gift? Why not? Greetings.
There are currently 2492 users online. 1 members and 2491 guests.
