Tanix TX3 Max TV Box Amlogic S905W Android 7.1 with New ALICE UI 2/16GB 2.4GHz WiFi 100Mbps LAN BT4.1
    Click image for larger version  Name:	20171223173006_79193.jpg Views:	1 Size:	112.8 KB ID:	696872
    Descriptions
    Tanix TX3 Max is a high-performance TV box, which runs on latest Android 7.1 system. Large 2GB RAM + 16GB ROM capacity ensures more smooth and flexible operation. You can enjoy the high-definition images and play large games in your home theater.
    Main Features
    ● Supports 4K resolution, enjoy super-definition images and breathtaking viewing effect
    ● H.265 decoding technology saves half of the bandwidth than H.264, so it can show vivid and rich image details
    ● 2GB RAM and 16GB ROM, large capacity allows you to download more applications and games in your TV box
    ● Amlogic S905W processor is adopted for smooth and flexible operation, no worries about slow running problem
    ● The latest Android 7.1 system, with open-source application store, you can enjoy whatever you like
    ● Supports HDMI 2.0 version, convenient to stream your photos, videos to TV screen
    Gearbest
    Adding the video presentation of Tanix TX3 Max with ALICE UX to your post:
    Android TV Box direct from China. English & Español
      Bit of a special happening to save a few dollaroo's
      $34.99 coupon: GBTX3MAX
      https://www.gearbest.com/tv-box/pp_1509684.html
      Ships - Jan 9
        Thanks to Gearbest we can have a close look at the Tanix TX3 Max TV Box Amlogic S905W Android 7.1 2/16GB 2.4GHz WiFi 100Mbps LAN BT4.1
        First let's have a look at what we get.
        Specification
        Brand: Tanix
        Core: Quad Core
        CPU: ARM Cortex-A53
        GPU: Mali-450
        Max. Extended Capacity: 128G
        RAM: 2G RAM
        RAM Type: DDR3
        ROM: 16G ROM
        System: Android 7.1
        Type: TV Box
        Processor: Amlogic S905W
        Audio format: AAC,APE,FLAC,M4A,MP3,OGG,WAV,WMA
        Photo Format: BMP,GIF,JPEG,PNG,TIFF
        Video format: 3GP,4K,AVI,DIVX,FLV,H.264,H.265,M4V,MKV,MP4,MPEG2, MPEG4,PMP,RM,RMVB,VC-1,VOB,WMV
        Support 5.1 Surround Sound Output: Yes
        Bluetooth: Bluetooth 4.1
        Interface: AV,DC Power Port,HDMI,RJ45,SPDIF,TF card,USB2.0
        Language: English,French,Germany,Italian,Spanish
        Power Supply: Charge Adapter
        DVD Support: Yes
        HDMI Version: 2.0
        RJ45 Port Speed: 100Mbps
        Power Type: External Power Adapter Mode
        Package size (L x W x H): 17.20 x 12.00 x 6.50 cm / 6.77 x 4.72 x 2.56 inches
        Package weight: 0.3850 kg
        Product size (L x W x H): 10.50 x 10.50 x 1.50 cm / 4.13 x 4.13 x 0.59 inches
        Product weight: 0.1516 kg
        Package Contents: 1 x TV Box, 1 x HDMI Cable, 1 x Charger Adapter, 1 x Remote Controller, 1 x English User Manual
        The Box
        What's in the box
        Display are, ports etc.
        Remove the base underside PCB
        Remove PCB: Top side, like the Heatsink idea
        Close look topside
        Close look at the Bits that make it happen
        The Clock for those that need to know, good looking indigo colour camera lightens it a little
          Not a bad looking Unit and the startup was good
          Google login etc, update and installed Apps easy
          Don't forget to update Google Services
          Flashy Intro
          WiFi, Ethernet and BT do as they should.
          Upper Notification and Lower task bars.
          An Adjustable Root nice to see.
          Test results are much the same as the mini version of the unit.
          Temps a little warmer than mini, maybe there has been come creative CPU tweaking.
          Alice UX is looking good, and great to see something creative.
          Not sure if you can replace the back drop Image as yet, did not look.
          Let's have a look see
          Setup Wizard
          Alice UI
          Installed Apps and weather UI
          Upper and Lower Bars
          System Information
          Enable/Disable Root
          Display Settings
          CEC Control
          DRM Information L3
          Ram and Storage Truth
          CPU-Z
          Geekbench
          A1 SDBench
          YouTube 1080
          TV Centre
          Hold Menukey in Apps to Uninstall
          A quick look around
          No doubt with Dual boot it will be more Interesting for some.
          Very easy setup and Use, good little budget Media Player I find
          Gearbest
            ..I got the mini 2/16 with the dualboot rom
              Any feedback regarding hd Netflix playback with stock fw?
              Is there any Android TV custom ROM available?
                Netflix 1080p and 4K requires Widevine L1. This is not supported by S905W
                  It has nothing to do with the soc. This one supports L1 DRM.
                    Does not support L1, confirmed by Amlogic 3 times.
                    As I know there is only one device mounting S905W and supporting L1. Curiously the producer is not allowed to purchase this SoC from Amlogic (only 4 companies can). I (and others) have my own idea about what is happening there, but as I said before, I am not going to talk more about this (not easy to proof).
                      Are you talking about m8s pro w?
                        Hello I acquired several, but I have only tried 1. The problem is that the Play Store can not be updated, I tried from the App in configuration it starts to download but it is not installed, also download several from apkmirror and tell me what is damaged archive. I do not know if it's TVBox's problem but they delay in advancing the downloads of the Play Store. Someone who has it and help me, thanks.
                          I want to install Unkilled but it gives me the error 495 already erase the data and the cache of the Play Store. The TVBox can send but not receive files via Bluetooth, I'll have to do more tests.
                            in the gear section... i don´t know how to change to another app where the "+" Tab as already one app... i want to change another app instead of one i wont
                              To replace apps you press the menu button on the remote inside of the app section that you want to change.
