UGOOS AM3 Amlogic S912 Android 7.1.2 2G/16G TV BOX 4K UHD 802.11ac WIFI Gigabit LAN Bluetooth
    This one has been around for a little while and looks like its had a bit of an Update, thanks to Gearbest
    As always good Ugoos quality build, 5v 3amp power supply, OTG Cable and a all metal Case.
    Ugoos AM3 TV Box is a high-performance TV box, which runs on advanced Android 7.1 system.
    Ultra-large capacity ensures more smooth and flexible operation. And it supports 32GB TF card for larger memory.
    Main Features
    ● It runs on Android 7.1 system for more smooth and flexible operation
    ● Supports H.265 decoding, high-definition and high-dynamic imaging effect
    ● 2GB RAM and 16GB ROM, ultra-large capacity allows you to enjoy more pleasure
    ● 2.4GHz and 5.8GHz Wi-Fi, dual frequency Wi-Fi provides you high-speed wireless transfer experience
    ● Supports TF card up to 32GB, easy to extend extra memory
    Lets have a look see.
    The Box
    What's in the Box
    Look Around all Metal
    Remove the base, RF Shields lets see how the heat is may remove later
    Out with the PCB, same deal RF Shield over Ram CPU again lets see how it goes
    Thanks to Gearbest
    For further review and Discussion
    http://freaktab.com/forum/tv-player-...-lan-bluetooth
