i96 PRO Android TV Box S905X - Android 7 2/16GB, 2.4GHZ WiFi Fast Lan BT
    Description:
    With the i96 PRO Android TV box at your disposal, you don't have to worry about that the boredom will enter your household.
    This stylish i96 PRO Android TV box will provide you with smooth experience to watch the video or play games.
    It is a perfect device for providing 4K ultimate HD video, you will see the movies with more vivid color, creates your own home theater easily.
    Have this Android TV box, you will have a wonderful and enjoyable time with your family, friends.
    It is more than a TV box, it will make your home smarter and happier.
    Features at a glance:
    - Android 7 operation system is one of the most popular operating systems around and will bring an unparallel level of controlling to your TV
    - Equipped with 2.0GHz Amlogic S905X CPU, and 5-core Mali-450 GPU
    - With the HDMI 2.0 data output, supports H.265
    - Supports multiple connections such as BT4.0, Ethernet 10 / 100M, 2.4GHz WiFi, USB flash drive, TF card (TF card is not included)
    - Supports Miracast, Airplay, DLNA
    Gearbest
    Today we can have a closer look at the i96pro thansk to Gearbest
    Specification
    Model: i96 PRO
    Type: TV Box
    System: Android 7.0
    CPU: Amlogic S905X
    Core: 2.0GHz
    GPU: Mali-450
    RAM: 2G
    RAM Type: DDR3
    ROM: 16G
    Max. Extended Capacity: TF card up to 64GB (not included)
    Maximum External Hard Drives Capacity: 1TB
    Decoder Format: H.265,HD AVC/VC-1,HD MPEG1/2/4,RealVideo8/9/10,RM/RMVB,Xvid/DivX3/4/5/6
    Video format: ASF,AVI,DAT,FLV,ISO,MKV,MOV,MPEG,MPG,RM,RMVB,TS,VO B
    Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: AV,DC Power Port,HDMI,RJ45,TF card,USB2.0
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: 3D Games
    RJ45 Port Speed: 10 / 100M
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Remote Controller Battery: 2 x AAA battery (not included)
    Product weight: 0.2000 kg
    Package weight: 0.3400 kg
    Product size (L x W x H): 10.00 x 10.00 x 2.00 cm / 3.94 x 3.94 x 0.79 inches
    Package size (L x W x H): 20.00 x 11.00 x 5.50 cm / 7.87 x 4.33 x 2.17 inches
    Package Contents: 1 x TV Box, 1 x Remote Controller, 1 x HDMI Cable, 1 x Charger Adapter, 1 x English User Manual
    Lets Have a Close look
    The Box
    What's in the Box
    Ports, not many.
    The Case or Clam Shell ?
    Underneath
    TopSide: Very small heat sink
    Oops maybe ?
    Lightshow around player 3 colours and off.
      Currently advertised with Android 6 has 7 running like most
      Not a bad looking unit, bit Led bling around the front and side
      Setup Ok, Google, Apps, and testing all good.
      Has Root no SU.
      No upper or lower bars.
      Temps about the same as other 50 to 80c pending of the work loads
      Heat sink was a bit small I though bigger maybe better.
      WiFi was only OK Just, Ethernet was the way to go
      Found Remote to be ok
      Let's have a look much the same as the other I series of boxes
      UI, Installed Apps
      Has root access
      Sytem Information
      DRM Info L3
      Ram And storage Truth
      CPU-Z
      Geekbench More >
      http://browser.geekbench.com/v4/cpu/5838156
      CPU
      Compute
      A1SD Bench
      WiFi...
        Hello, very cool this box tv, I have one like this but she is without the firmware. it would be possible if you had him post in the mega so I could relive this tv box. I will be very grateful if possible.
