Current version :A1_709N0
Based on :A1_708N0
Android version :7.1.2
Fits for: RK3328 DDR4/DDR3/LPDDR3 4G+16G / 32 G
Ethernet:1000M
USB zip :
https://beelink-my.sharepoint.com/pe...fb558c27ab7bb1
SD zip :
https://beelink-my.sharepoint.com/pe...873c72cdb72882
Improvement:
1. The problem that the Amazon prime video gets crash often has been solved already .
2. We have maken some changes to maintain this system .
3. You can get into the recovery mode when you click the recovery button .
4. The third -party apps could read more information about external storage to some degree .
5. Some shortcuts have been added to remote for popular demands , as the picture shows,
6. The OTA news from 70XN0 to 709N0 has been sent to your tv box already .
Some tips for updating :
1. USB updating :
1) Install the DriverAssitant_v4.5 first and double click the DriverInstall.exe , then you need to choose the "install the driver"option to finish this installation ;
2) Open the USB bunning tool which is named FactoryTool v1.43e and then double click the FactoryTool.exe ,now it's time to click the "firmware"to load it well .
3) Click the "start" and hold the reset button still to connect the double USB cable , then you can take it easy to wait for the updating .
2.SD updating :
1) Format your sd card with the FAT32 fromating style . and then you need to copy the update.zip file to the root of the SD card ;
2) Insert the sd card to the port ;
3) Wait for the updating pop news and choose the update option . you need to make sure that Power supply must be firmly good enough to finish this updating , power outages would contribute to a failure .
email : [email protected] / skype : +86 18772960513
