i95 PRO Android TV Box S905X - 2/16GB ROM
    Specification
    Model: i95 PRO
    Type: TV Box
    System: Android 6.0
    CPU: Amlogic S905X
    Core: 2.0GHz
    GPU: Mali-450
    RAM: 2G
    RAM Type: DDR3
    ROM: 16G
    Max. Extended Capacity: TF card up to 64GB (not included)
    Maximum External Hard Drives Capacity: 1TB
    Decoder Format: H.265,HD MPEG1/2/4,RealVideo8/9/10,RM/RMVB,Xvid/DivX3/4/5/6
    Video format: ASF,AVI,DAT,ISO,MKV,MOV,MPEG,MPG,VOB,VP9
    Audio format: AAC,APE,DTS,FLAC,MP3,OGG,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: AV,DC Power Port,HDMI,LAN,Optical,TF card,USB2.0
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: 3D Games
    RJ45 Port Speed: 10 / 100M
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Remote Controller Battery: 2 x AAA battery (not included)
    Product weight: 0.2650 kg
    Package weight: 0.3600 kg
    Product size (L x W x H): 11.70 x 11.70 x 2.50 cm / 4.61 x 4.61 x 0.98 inches
    Package size (L x W x H): 18.00 x 12.00 x 5.00 cm / 7.09 x 4.72 x 1.97 inches
    Package Contents: 1 x TV Box, 1 x Remote Controller, 1 x HDMI Cable, 1 x Charger Adapter, 1 x English User Manual
    Gearbest
    Thanks to Gearbest we can have a look at the i95
    i95 PRO Android Amlogic S905X 2.0GHz Mali-450 RAM: 2G RAM Type: DDR3 ROM: 16G 2.4GHZ WiFi and BT4i95 PRO
    Much the same as others, a different case
    Lets have a peek
    The Box
    What's in the box
    Ports
    The Case
    Topside, old pcb date.
    Closer
    Underneath, that 3 button deal again
    The Case
      Continuing on, much the same as the previous i96 tested
      Tho i95 has Video (composite) out no cable supplied, and SPDIF.
      Its Doing the job, Google setup and Installed Apps ok
      WiFi and Ethernet about the sames as previous i96
      Temp 45 ~ 80c when pushed..
      Has Root access, no SU, and No Upper and Lower as previous i Units
      Be interesting to see if there will be any updates for this i series..
      All else much the same UI, installed Apps and performance.
      Let's have a look
      UI and Installed Apps
      System Information
      Ram and Storage Truth
      DRM Info L3
      Ethernet
      WiFi
      CPU-Z 3 frames
      Geekbench
      CPU > http://browser.geekbench.com/v4/cpu/5864307
      Geekbench
      Compute
      A1SD Bench
      AIDA64 8 frames @ 4.5 sec per frame
      Gearbest
        i need firmware for this tv box
        firmware tv box m95 Amlogic Quad Core 64bit 1GB RAM/ 8GB ROM 8189ETV I have a TV box Model M95, I put an incorrect ROM, and it was dead, I have downloaded many roms but they only brick it Any link that works to download a correct version? Thanks in advance... A greeting.
