Tanix TX2-R2 rk3229 2GB RAM - bricked after flashing a wrong firmware
Good evening, I have a tv box tanix tx2 that, after installing a wrong firmware, it is bricked. Inside there is a Samsung klmag2ge2a-a001 emmc. I am attaching a photo. Is there a possibility to unbrick it? Thanks a lot to everyone.You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos -
if you install the wrong firmware it should be just softbriked, you can always restore the original firmware by using the SD Card method, but you need to basically prepare the MicroSD card, using the RK SD card tool, using the corresponding firmware img, insert it on the box, restart it, and the installation should begin.
Originally posted by miguelkleman View PostI try restore by using SD Card method but no result.
Method by short pins Nand works to writing memory but too no result (LED light off and no video in HDMI)
maybe the "Nand" is bricked , what about the Tests under "AdvancedFunction"
is the Offset & Output of the IDB Sectors okay ??? Did you checked the Logs of the
Flashtool ??? .
greetings / gefattern
Tests under "AdvancedFuncion" all failure.
The logs is below :
19:42:50 201 Layer<1-1-5>ownload Boot Start
19:42:52 448 Layer<1-1-5>ownload Boot Success
19:42:52 450 Layer<1-1-5>:Wait For Maskrom Start
19:42:53 030 Layer<1-1-5>:Wait For Maskrom Success
19:42:53 031 Layer<1-1-5>:Test Device Start
19:42:53 033 Layer<1-1-5>:Test Device Success
19:42:53 034 Layer<1-1-5>:Get FlashInfo Start
19:42:53 034 <LAYER 1-1-5> INFO:FlashInfo: 00 F0 D1 01 00 04 04 00 28 00 01
19:42:53 036 Layer<1-1-5>:Get FlashInfo Success
19:42:53 037 Layer<1-1-5>:Prepare IDB Start
19:42:53 086 <LAYER 1-1-5> INFO:CS(1) (14910MB) (SAMSUNG)
19:42:53 094 Layer<1-1-5>:Prepare IDB Success
19:42:53 096 Layer<1-1-5>:Erase IDB Start
19:42:53 110 Layer<1-1-5>:Erase IDB Success
19:42:53 144 Layer<1-1-5>:Reset Device Start
19:42:54 146 Layer<1-1-5>:Reset Device Success
19:42:54 149 Layer<1-1-5>:Wait For Maskrom Start
19:42:54 638 Layer<1-1-5>:Wait For Maskrom Success
19:42:54 640 Layer<1-1-5>ownload Boot Start
19:42:56 858 Layer<1-1-5>ownload Boot Success
19:42:56 860 Layer<1-1-5>:Wait For Maskrom Start
19:42:57 345 Layer<1-1-5>:Wait For Maskrom Success
19:42:57 347 Layer<1-1-5>:Test Device Start
19:42:57 349 Layer<1-1-5>:Test Device Success
19:42:57 350 Layer<1-1-5>:Get FlashInfo Start
19:42:57 351 <LAYER 1-1-5> INFO:FlashInfo: 00 F0 D1 01 00 04 04 00 28 00 01
19:42:57 353 Layer<1-1-5>:Get FlashInfo Success
19:42:57 354 Layer<1-1-5>:Erase Flash Start
19:44:01 658 Layer<1-1-5>:Erase Flash Success
19:44:01 695 Layer<1-1-5>:Reset Device Start
19:44:02 699 Layer<1-1-5>:Reset Device Success
19:44:07 657 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
19:44:09 658 INFO:RKU_ResetPipe-->DeviceIoControl OK
19:44:14 659 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
19:44:14 660 Error:ReadFlashIDProc-->RKU_ReadFlashInfo failed,err=-3
19:44:22 040 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
19:44:24 040 INFO:RKU_ResetPipe-->DeviceIoControl OK
19:44:29 041 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
19:44:29 041 Error:ReadChipInfoProc-->RKU_ReadChipInfo failed,err=-3
19:44:41 094 Layer<1-1-5>ownload Boot Start
19:44:43 314 Layer<1-1-5>ownload Boot Success
19:44:43 316 Layer<1-1-5>:Wait For Maskrom Start
19:44:43 803 Layer<1-1-5>:Wait For Maskrom Success
19:44:43 805 Layer<1-1-5>:Test Device Start
19:44:43 806 Layer<1-1-5>:Test Device Success
19:44:43 808 Layer<1-1-5>:Check Chip Start
19:44:43 810 Layer<1-1-5>: Check Chip Success
19:44:43 811 Layer<1-1-5>:Get FlashInfo Start
19:44:43 812 <LAYER 1-1-5> INFO:FlashInfo: 00 F0 D1 01 00 04 04 00 28 00 01
19:44:43 814 Layer<1-1-5>:Get FlashInfo Success
19:44:43 815 Layer<1-1-5>:Prepare IDB Start
19:44:43 816 <LAYER 1-1-5> INFO:CS(1) (14910MB) (SAMSUNG)
19:44:43 848 <LAYER 1-1-5> INFO:FindBackupBuffer-->No Found Tag
19:44:43 849 <LAYER 1-1-5> INFO:FindBackupBuffer-->No Found Tag
19:44:43 850 <LAYER 1-1-5> INFO:FindBackupBuffer-->No Found Tag
19:44:43 851 <LAYER 1-1-5> INFO:FindBackupBuffer-->No Found Tag
19:44:43 853 Layer<1-1-5>:Prepare IDB Success
19:44:43 854 Layer<1-1-5>ownload IDB Start
19:44:44 002 Layer<1-1-5>ownload IDB Success
19:44:44 004 Layer<1-1-5>:Reset Device Start
19:44:45 006 Layer<1-1-5>:Reset Device Success
19:44:45 009 Layer<1-1-5>:Wait For Loader Start
19:44:45 645 Layer<1-1-5>:Wait For Loader Success
19:44:45 648 Layer<1-1-5>:Test Device Start
19:44:45 650 Layer<1-1-5>:Test Device Success
19:44:45 652 Layer<1-1-5>ownload Firmware Start
19:44:45 766 <LAYER 1-1-5> INFO:Start download image,total=976022388
19:44:45 796 <LAYER 1-1-5> INFO:Start to download trust,offset=0x4000,size=4194304
19:44:46 047 <LAYER 1-1-5> INFO:Start to download uboot,offset=0x2000,size=4194304
19:44:46 302 <LAYER 1-1-5> INFO:Start to download misc,offset=0x8000,size=49152
19:44:46 309 <LAYER 1-1-5> INFO:Start to download resource,offset=0xa800,size=6295040
19:44:46 713 <LAYER 1-1-5> INFO:Start to download kernel,offset=0x12000,size=7933868
19:44:47 193 <LAYER 1-1-5> INFO:Start to download boot,offset=0x18000,size=1016984
19:44:47 258 <LAYER 1-1-5> INFO:Start to download recovery,offset=0x2a000,size=11468800
19:44:47 979 <LAYER 1-1-5> INFO:Start to download system,offset=0xa4000,size=940863488
19:46:16 491 Layer<1-1-5>ownload Firmware Success
19:46:16 494 Layer<1-1-5>:Reset Device Start
19:46:17 499 Layer<1-1-5>:Reset Device Success
Thanks for help-me.
Originally posted by miguelkleman View PostTests under "AdvancedFuncion" all failure.
The logs is below :
Thanks for help-me.
so you got it back to live , is it correct ???
Unfortunately No!
All my tests in "AdvancedFuncion" is bad, but I can upgrade Nand Flash with RKBatchTool (view log above).
After update the device, TX2-R2 Tanix, ramains bricked, no LED light and, no video HDMI and does not obey remote control.
I try the firmware TX2_3229_6.0_B4_8703bs_20170608.img, exist another?
The SD card method what firmware is?
Originally posted by tvboxplus View PostGood afternoon, in the software "tanix burning rom" does not detect the box, it appears "no TANIX devices found" ... Has anyone solved with the pins?
do you mean u have a flashing Tool from Tanix , to flash your Rom ???
If , upload , for other Users . Did you install the RKDrivers 4.5 ???
Did you use the right USB port ???
first i am not sure what Firmware exist for your Box , but i think well , did you use the
"search" for more Info ??? , for the SDCard way u can use all compatible ".img" files .
It looks like something is wrong with the "RKU" thing , but i am not the Pro !!!
good luck / greetings / gefattern
Hi ,
Many thanks in advance.
Good evening, I used the software for the USB connection of the box, but I loaded an incorrect firmware and from that moment does not turn on anymore, the LED is off, the software does not recognize it anymore now. Is there any solution with the short pins?
first what Tool did you use, Batchtool 1.7 or 1.8 / Androidtool 2.35 or higher ???
Did you install the latest Drivers , RKDrivers 4.5 ???
Of course there is a way to restore your Box , if not hardbricked , you can use the
MaskRomMode (shortPins) to restore with Stockrom , maybe this :
https://chinagadgetsreviews.com/down...x2-tv-box.html
http://freaktab.com/forum/tv-player-support/rockchip-based-tv-players/rk3229-devices/firmware-roms-tools-bg/626506-tanix-tx2-firmware-needed
If you use the "Search" u can find many Info over your Box and how to "shortPins"
Hope you can get it back to life , good luck ,
I download and flash the TX2_3229_7.1_20180308.img firmware OK.
Then I get Androd Recovery Mode OK.
Wipe Data/Factory Reset OK
Wipe Cache Partition OK
But when click in Mount/System I get the error : E:Failed to Mount/System (Invalid Argument)
When I click in Reboot System Now the TVBOX start but freeze in screen showing TX2.
Thanks for help.
There are currently 3169 users online. 2 members and 3167 guests.
