My box starts ok and works well on all apps.. But as soon I connect my Hard on any of the 2 usb ports , without a second delay .,. It restarts and then keeps restarting until I disconnect my hard... Please help me what could be the issue.. I have done a factory reset and installed the firmware as well but in vain
T95Z Plus restarts on USB connect
Hi I am facing this issue from last two days if anyone could get me a solution please
My box starts ok and works well on all apps.. But as soon I connect my Hard on any of the 2 usb ports , without a second delay .,. It restarts and then keeps restarting until I disconnect my hard... Please help me what could be the issue.. I have done a factory reset and installed the firmware as well but in vainTags: None
Originally posted by yudi.15 View PostHi I am facing this issue from last two days if anyone could get me a solution please
Use an active usb hub then you can plug everything on it...
Cheers
Originally posted by yudi.15 View PostThanks a ton my issue resolved after connecting usb 3.0 powered hub with this box... don't know why all of a sudden this problem raised but after the powered hub solution it's working great ....thanks AGAIN
There are currently 1163 users online. 1 members and 1162 guests.
