MXQ-4k device bricked help urgent
i have this box now problem is i can connect using mask mode and when i write firmware it gives me error IDB FAILED i dnt know what to do now pleae guide me and please provide me firmware for this box tried almost 10+ roms non working always getting IDB fail error. please check the images below and solve my problem guys thanks in advanced
Tags: None
Originally posted by vijender91 View Posti have this box now problem is i can connect using mask mode and when i write firmware it gives me error IDB FAILED i dnt know what to do now pleae guide me and please provide me firmware for this box tried almost 10+ roms non working always getting IDB fail error. please check the images below and solve my problem guys thanks in advanced
for flashing a RK Box , it is only the "LoaderMode" needed , do you have the
Stockrom , for restore ??? , did you ever " erasedFlash" before you flashed a
new Rom ??? Please use AndroidTool , look here :
Datei: RKTools.zip. Die Datei wurde von einem User hochgeladen. Laden Sie auch kostenlos Dateien hoch mit File Upload.
greetings / gefattern
and https://leelbox-tech.com/web/firmware
They works for me, with leelbox I have no wifi but I dont need it.
Mxq pro 4k rk3229 1/8gb emmc and board r329q v3.0Â I can only flash firmware with boatloader 2.32 in my box. All firmware work flashing but only a few boot up.
No sorry, I can only flash with bootloader 2.32 and there is not so many more for me. A lot says 2.32 but are 2.31
Have you tried these site:Â https://www.chinagadgetsreviews.com/firmwares
and https://www.entertainmentbox.com/and...are-downloads/
Leelbox https://mega.nz/#!h3gkgCTK!apouetsDz...eIfrhGZjLD4peM
That one is stable for me, I have put a bigger heatsink on it and now it's very good for iptv.
..They gave one of their colleagues the model androida mxqpro 4k ... I was blown off by a transistor at the entrance of the charger for the electrolyte see the first two digits a1 transistor is smd in advance thank youYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 3080 users online. 0 members and 3080 guests.
