tanix tx3 mini - can i use it with an external usb drive as a torrent client or i will destroy the tanix or the usb disk?
    hi,
    i would to use the tanix tx3 mini as a torrent client, alwasy on, with an external usb disk.
    i don't know how android handle external usb disk.
    a long activity can overload my usb disk, or this operative system will correcly handle my external usb disk using writing cache and other tricks?
    thanks.
    Originally posted by abioneperhobby View Post
    hi,
    thanks.
    Hi ,
    most Boxes have because of bad chinese Powersupply , Problems with connected
    Harddrives , but if you use a better one with only more amp , it will work much better .
    Example . old 5V/2000amp / better 5V/3000amp ,
    but a OTG USB Hub with Powersupply can help you too .
    hope it helps
    greetings / gefattern
      thanks.
