Logitech C310 hd and Cozyswan s400
Originally posted by bttf View PostI buyed the cozyswan s400 with android 4.2.2. If i buy too the Logitech cam c310 hd USB can i use on this mini pc or i have to install a particular firmware on it ? Can you please tell me how install this cam ? I have only attach the cam ? Thans
I try the logitech c310 that works very well on windows.
Then i connected on s400: the s400 don't recognize it. I click on
"webcam" in menu config and the display turns in black for 1/2 second
then return to menu.
Then i try to activate "connect to usb"... Nothing.
Plese can you tell me if s400 must recognize at least the webcam after
inserted in on microusb or i have to install other driver ?
Other information. The microusb adapter of s400 is a 5 o 8 pin microusb ? I
have to know this because i want try another adapter: when i insert the
usb of the logitech i see that the connector of cam don't go totally in
the adapter (1/3 cm. go out and it can "play"-move on right or left). Is
normal ?
There are currently 2593 users online. 3 members and 2590 guests.
