[ROM] Mecool KIII Pro VITMOD-ATV (Android TV 7.1.2+TVHeadend+Neutrino)
okey, I download the file but how I can install it ?
I tried one more time. all of trials was failed. I installed vitmod-5.0-recovery.zip then I selected the k3pro-ota-vitmod-5.0-27122017.zip file during recovery mode but it was occured error. then I tried to installed update mode when android was running. It was again failed. plaese, someone explain how we can install the firmware.
thank you for assistant.
Hi garnik_a,
yes, I did. thank you for support. Second questionHow can I install the .apk file ? There is not any APK installer in this rom. I could install the .apk file inSCV1 ATV version via apk installer, but there is not any program. I searched the application installer in google play. I didn't find any program. Please, can you help me to install any apk file in VITMOD firmware ? SCV1 ATV
Garnik,
Before I sent email, I tried to install in file browser but it was only tick at right side. There is only copy, paste and rename option. I want to install IPTV Player Pro (not free) on .apk file. I don't find any solution.
http://bc.vc/bv4ZNh6 (IPTV Player Pro, Full 1.5 version)
after loading the k3pro-img-vitmod file with usb tool, how should I proceed with the next two files?
How should I start vitmod-5.0-recovery? Where should I copy and how to activate this file?
How should I treat VITMOD-ATV 5.0?
If possible I ask a detailed explanation as I am not very expert.
Thanks 1000
There are currently 1796 users online. 2 members and 1794 guests.
