Need firmware update help
    Hi
    i have a M8 802 OTT amlogic
    m9&m8 v0.92 2015/04/17
    m8 v 1.0 3015
    I dont know what the newest update should be for this type and im really new to this, I do know that the box is bricked and I have a sd card with adapter at the ready I also know how to reset the box using hidden button just need the correct firmware to install and hopefully unbrick the box. Would be good to update to the latest android os as kodi 17/18 needs the higher os.
    thanks
