MXQ Pro 4k goes no further than the word ANDROID
    Hey team,
    Have a MXQ Pro that can't get past Android, was working perfectly fine. No changes made by me and less than a month old.
    Some Google searching suggests that it my be bricked and to try a soft reset. Tried this without luck. Is running 7.1.
    Any advice would be appreciated.
    Cheers
    Hello,
    So i guess you have an Newer MXQ PRO 4K Box with an S905W CPU.
    Can you please confirm that?
    Neomode
      According to the description of what I bought they say S905X Quad core.
      Cheers
        https://yadi.sk/d/weKOyhxQ3R9z4F  I have upgrade my mxq pro 4k rk3229 to 7.1.2 so there is box with this version firmware to. Best if you could take it apart and read on chip.
          Sweet will check and come back to you
            On the Android recovery screen it has RK322x box
              Then you have a rockchip box and the firmware above should work.
                Are you able to provide me with some instructions please. I have tried following some instructions I found online that use the USB burning tool but I can't get the MXQ to show up in the burning tool.
                Cheers
                  Hello Scratch
                  You have an Rockchip Box and the USB Burning Tool is for AMLOGIC Boxes so it can´t regonize the MXQ.
                  For Rockchip you need the Android Tool you can find here --> http://freaktab.org/4a4abef777368a8d
                  You also need the Drivers these are included in the Download.
                  Neomode
                    Thanks, I will give this a try now.
                      Ok, box picked up ran firmware and still stuck on Android screen. I must be doing something wrong.
                      Help please.
                        Hi team, thanks for the help. The box is running again!!! A quick question Neomode, what version of Android is the firmware you provided? Is it 6?
                          My Firmware is not for the Rockchip Boxes sorry.
                          Regards
                          Neomode
                            You beauty Rockabilly, up and running again and looks exactly like what I had.
                            Thanks to all of you for the help given, you're all rockstars!!!
                              Hey guys, I have another quick question when I checked the storage of the box I have it says it's only 4GB, would this be right or is it because of the firmware I have loaded? It should be at least 8GB.
                              Cheers
