It was time to make a proper ATV rom for this box, now you have it!
Many thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog V1:
- Based on latest fota 20171020
- Cleaned lots of stuff...
- Lot smother... and faster
- Added TWRP
- It should have a better cpu usage/ram.
- Removed Navigation bar. ( Dont ask for it you wont going to get it back... )
- General optimization and how the ram is used, should better now.
- Some permissions fixed.
- Double press on Home button bring the APP Switch Menu ( Use del key on keyboard to close open apps )
- Working ATV google remote control!
- Netflix FHD Android TV app, install from Playstore
- Netflix 5.1 Sound
- 4k Youtube support!
- FTMC Build 31.
- Some audio mods ( Experimental )
- Settings menus working ( VPN can be added... )
- Added lots of Kl's
- initd.d support.
- Fixed some gamepad drivers.
- Xbox360 wireless Gamepad, original and Chinese clones?! ( well it works with my clone adapter... )
- PS3/PS4 gamepad support(only with cable...)
- Added Dragonrise USB HID game controllers.
- Fixed auto frame switch in kodi. It only works on FTMC(included) SPMC 16.5.5 -> Up, on kodi 16.1 doesn't work because is to old(misses a lot of fixes for the new S9xx devices), Kodi 17 its a it and miss this days!
- Optimized some animation stuff!
- A lot of other stuff.........
- And of course all the other ATV mambo jambo...
Bugs V1:
- If in netflix a movie/tv show dont work change the audio to non- 5.1 audio inside the movie/tv-show and wait a few secs and it should start ok, this affects all tv's that dont have 5.1 audio support...
- No Googlecast because its not working at all now in A6, on non signed devices!
- If you install magisk, you need to install after the magisk app manually...
- I bet you guys/girls tell me if they are more
Want to buy me a beer?
Download:
- DOWNLOAD HERE SCV1 ATV ROM
- MD5: C26522DB8A69514670D2B8337982E5EF
Install instructions:
- Use usb burn tool
Where to buy:
1º BOOT TAKES AROUND 5 MINUTES!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
