UT3 bricked / IDB bricked ???
Originally posted by digitalriver View Post
Are you have a link?
i am not sure if it really helps , like the Statement of the Dev. it only is for RK3128 , but in
Theory it could maybe be updated by another Dev. ??? , but this shows that there must be
a Way .
If you still both want to try : m.panuso.com/77785388.html , that is the Link u need for it ,
sorry but i can not copy & paste on my UT4 , so i must write down .
greetings / gefattern
did you managed to load it , thanks , to both for your efforts to help .
If i want to try the SD Way with "Wasser" is this another Way then
creating a SDCard with Win32Disk... or the used RK Disk Tool ???
Really dont know what i can do to restore , if this PCBs are so called
"unbrickable" , even the TWRP Way dont work , like suggested by a
User called "Remixio" or similar , no Output on Screen , no fix , sh.... .
Maybe i have to go further to a new RK3399 Box ???
I still have to test the "Loaders" u uploaded .
Originally posted by RISCy Dude View Post"....sorry but i can not copy & paste on my UT4..."
Hello, I am curious about this.
Chrome wont let me "copy&paste" on Webpages , but i am not the only one ,
i know somewhere here in a Thread a User had similar Problems .
Maybe i only have to clean Chrome or install Rom new , not sure why it not
work ,
I don't have much experience on Chrome, but the issue sounded vaguely familiar. It seems I recall a box that would not paste in to an empty field, but if you entered a letter/number in to the field, it could be highlighted and pasted over. I don't recall what box or Android version it was. I was just curious. :-)
Hi ,
i only can copy&paste inside the "www" Field , i want to flash it once new and see what happens ???
but maybe it has to do with my fully debloated Rom ,
So seems you un bricked or run from sd?
Uncortunately, I have not yet been successful in unbricking my original UT3. Though iit will boot/run Ugoos Ubuntu from SD card.
Sux! But better than nothing, I suppose. :-)
Hmmmm just curious if last firmware flashed was linux as I had a bitch time after putting it on rkm. I had to use gparted in linux and re format in that once seen.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Hi once more ,
here are some zipped Pictures of the "bad Block state" with Rockchip
Developer Tool 1.7 & "IDB output" with Android Tools ,
maybe someone knows something , i even was able to deleting all
Blocks with RK DeTool , later i try the Linux way again ,
press thumbs
Hi ,
here are some News about restore , in this PDF you can find Infos that the IDB can be loaded for boot
from a external Device , if i understand the Pictures inside the PDF right :
https://www.file-upload.net/download...75/RK.zip.html
RK Developer Tool is uploaded too , inside File .
Hi to all ,
with help of Mo123 and HDDRAWCopy Tool & .imgc File of a UM3/307 Rom ,
my good old UT3 booted since a long long Time for the first Time again , i am
really happy with that , hopefully it is now possible to flash and restore it , but
that i do not know until now , press thumbs ,
I am not sure but i think this Tool shall work with .img Files too , maybe i can try
the latest 7.1.2 for UT3 ,
Or I can try from a working device to make a backup, but someone must give instructions how to make a backup imgc file with HDDRawCopy.
If someone can make an imgc file from Ugoos Linux single boot perhaps, we can try to run it from a micro-sd card and erase emmc perhaps to revive it.
today i gone try to do it with a .img File , without c , if you load a .img to HDD the Tool shows (RAW) in the Image
Name , hope it works , press thumbs ,
have to report it does not boot , only Blackscreen , waited long enough , but i was able to reach
the "Teamwin" Bootscreen , till i tried to boot to Recovery , we need for sure someone that makes
Backup with HDDRawCopy of existing bricked Boxes from here , maybe Ugoos can help us with
that , what do you think ???
There are currently 2699 users online. 1 members and 2698 guests.
