Problem with Mic input
Hi, just buy a Alfawise H96 Pro+ Android 7.1.2 (firmware: q201_9377-userdebug 7.1.2 NHG47L 20171020 test-keys), its all ok, great performance, but the only problem is the input voice with a usb microphone (an airmouse with mic by Probox2 Remote+ that work perfect on Minix X-H8plus). That is no recognized by Android, i have check all permission, but nothing, "Ok Google" for input voice dont start. The same with other voice recorder app. I have try also with two webcam with mic, but same bad result. Codec? Driver? Some suggestion pls? Thank you very much! Rob
Tags: None
Originally posted by robros61 View PostHi, just buy a Alfawise H96 Pro+ Android 7.1.2 (firmware: q201_9377-userdebug 7.1.2 NHG47L 20171020 test-keys), its all ok, great performance, but the only problem is the input voice with a usb microphone (an airmouse with mic by Probox2 Remote+ that work perfect on Minix X-H8plus). That is no recognized by Android, i have check all permission, but nothing, "Ok Google" for input voice dont start. The same with other voice recorder app. I have try also with two webcam with mic, but same bad result. Codec? Driver? Some suggestion pls? Thank you very much! RobMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1922 users online. 0 members and 1922 guests.
