I don`t understand why people are having so much trouble with Ver 3 boards?
I`ve had my MK908 for a few months now and havent had any issues! With all the GREAT work from Finless and ALL the other developers here, my ver 3.0 stick is running Great! I`m running the 1.3 ver of Hoabyscr ( sorry I missed spelled) here w/XBMC with no issues at 1080P/60hz. i do have a gig usb ethernet adapter, a 5v 3amp power supply as advised from these forums. Every new rom that comes out runs like a champ! Am I one of the lucky ones because of no issues? I haven`t modded my stick in any way, no heat issues, no freezes or randome reboots. nothing! i do have the video jitter like everyone else only on certain movies. and I`m sure that will be taken care of sometime soon. thanks for all the Great work done here!!!Tags: None
Originally posted by jetski1963 View PostI`ve had my MK908 for a few months now and havent had any issues! With all the GREAT work from Finless and ALL the other developers here, my ver 3.0 stick is running Great! I`m running the 1.3 ver of Hoabyscr ( sorry I missed spelled) here w/XBMC with no issues at 1080P/60hz. i do have a gig usb ethernet adapter, a 5v 3amp power supply as advised from these forums. Every new rom that comes out runs like a champ! Am I one of the lucky ones because of no issues? I haven`t modded my stick in any way, no heat issues, no freezes or randome reboots. nothing! i do have the video jitter like everyone else only on certain movies. and I`m sure that will be taken care of sometime soon. thanks for all the Great work done here!!!
With your current ROM, have you tried to run it using the original power supply? If not, could you please try with that. Does the ROM boot up successfully?
anhil
Originally posted by anhil View PostVery interesting! Have you actually opened your MK908 and verified that there is v3 printed on the PCB? What is the date printed on the PCB?
anhilIf my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
Originally posted by hoabycsr View PostI believe there are at least 2 V3's... one works normal, the other sucks.
Here is what I have running
First Hoabycsr, my apologies for miss spelling your name sir. My stick is dated 2013.5.13 and was purchased late May, also, before I received the stick, I heard that the enclosed power supply was junk so I ordered this one: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1. I am also using this adaptor for internet: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 , this is what I use to control the whole thing; http://www.amazon.com/GKM681R-Wirele...ywords=gkm681r thru a powered 4 port USB hub. My wifi router is only 10 feet away and I only connect at 65meg, but I had a gig Ethernet cable accessible so why not use it! I running rom: MK908-android.4.2.2.jjhmod.v1.3 and XBMC runs great! Yeah, even it crashes every once in a great while. With that, who needs Netflix. And until I see that a REALLY good fix is available, I'd say I'm set for awhile. Yes I have used the original supplied power adapter and it seemed to work, but why take the chances. and I have flashed a lot of roms since and all booted fine. The one mentioned above worked good so I have stuck with it for the past month or so. Thanks again to all the developers in this forum! Program on gents, program on!! have one on me!
Originally posted by pdjm View PostI purchased my unit in the end of may, it's a v3 revision 13/5/2013 and like jetski1963 i don't have problems. It really seems there are at least 2 v3's. My unit can boot all the kernels/roms from hoabycsr and finless. I'm using the original power source 5V 2A
Originally posted by maqros View Postmy one is the same, with no one issue with any custom ROM. got it a week ago from aliexpress.
so how can anyone find out the sick version they got if its good or bad ???
opening the stick and looking at the pcb and checking
- good one version3a revision: 13/5/2013
- bad one version3b revision: xxxxxxxx ???
anyone got a bad v3 stick revision date?
is dated 2013.05.13, Would also like to know if there is a way to tell which V3 board you have!
Originally posted by Ridata View Postok so boths pcbs say v3 13-05-2003
but some have issues and some dont have any problem
can non working and good working ownews post HQ pics of their PCB?
maybe it was just bad production?
As it works fine on the stock ROM but not custom ROM's which sucks as the stock ROM lacks any form of decent functionality compared to the custom ROM's the devs on here are making.
looks just like mine
My V3 board looks just like your pictures. if you look close, you can see GND ANT at the lower right of the date stamp. the G and N are upside down! too funny! and I have the same peal type thermal something or other for the back side heatsink. This is glued to a smd. No other distinguishing marks as to V3a or V3b.
It does not make any sense. You all got the same board. Same assembly day. And some got issues and some are great?
What about the power supply are you using the same as in pictures above?
What about the memory chip brand? Is the same manufacturer for all? I remember that in other android devices the memory chips were different
I am one of those that have an "earlier" (ordered in June, received in beginning of July) V3 board that doesn't have any problems. If you are needing comparisons, there are numerous chipset pics in my sig (under MK908 cooling mod post, click on the thumbnails in post to enlarge). Maybe you can spot a difference that could indicate manufacturing differences?Question Reality: Find Your Own Truth!
My MK908 Cooling Mod and Breakdown : HERE
My RK3188 Github Repos (NOTE: Works-in-Progress!) : HERE
Sent my Epic4G AND Backflip into nearspace... what have YOU done with your phone?
Want to say thanks for something I did/said or DONATE to my drink fund?
Originally posted by thesawolf View PostI am one of those that have an "earlier" (ordered in June, received in beginning of July) V3 board that doesn't have any problems. If you are needing comparisons, there are numerous chipset pics in my sig (under MK908 cooling mod post, click on the thumbnails in post to enlarge). Maybe you can spot a difference that could indicate manufacturing differences?
However there is this, Not sure how relevant, I borrowed one of your pictures ope you dont mind
Yours
Mines
The number at the bottomw left of the board, yours has 1322, mines has 1326,
Anyone know what this number represents, Revision number of the board maybe?
P.S.Nice cooling mod might try this!
There are currently 2803 users online. 0 members and 2803 guests.
