H96 Pro+ Portrait
H96 Pro+ Portrait
Does anybody have a problem with this box (Android 7. 1. 1) running apps that only run in portrait mode? I only get half of the screen like in the attached picture, it shows the spotify login screen.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
HOriginally posted by dfitz1000 View PostDoes anybody have a problem with this box (Android 7. 1. 1) running apps that only run in portrait mode? I only get half of the screen like in the attached picture, it shows the spotify login screen.
do you use the Stockrom ??? there is a good CustomRom from Superceleron
for this Box , here , but be patient this Boxes all have different Specs , before
you must be sure to have the right one (blue and green PCBs) .
I think your "portrait" Problem is a Rom Bug ???
greetings / gefattern
Hi gefattern, yes I use the stock rom. My guess that this was a rom problem, I posted details of my type of box in the attached thread (second last post) but it seems that the superceleron roms are not compatible with my boxHello guys, i would like to flash an custom rom on my H96 Pro. Could you please help me with the choice of the correct Firmware? I took some pictures from my
I didn't want to say that there is no working firmware for this Box (but now I seem I was), it's just that Your type of Box never happen to be evaluated if it works with superceleron;'s Roms, so it may be not safe to flash them.
And as there is no confirmed official firmware for this Box (however one for other PCB may work) You may brick Your device without a way to fix it.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 3056 users online. 0 members and 3056 guests.
