TX7 Android 7.1 Amlogic S905X Quad Core 2/32gb Dual Band WiFi 2.4GHz + 5GHz Bluetooth 4.0
Originally posted by blackie333 View PostPlease guys, nobody has a copy of the firmware bodrick linked here?
https://forum.freaktab.com/forum/tv-...278#post712278
Thank you very much and sorry, my eyes aren't so good now as before
Will try this fw. for my TX7 revival.
Better off dual booting this box.
Try CoreELEC OS
Booting from SD Card
Works great for KODI.
Thanks, unfortunately after unzip I found out inside is the same firmware version.
I tried to flash the box again with "usb burning tool", box got the same error at 9% as before:
[Err]--failed:Verify Failed with sha1sum, origin sum "78813f7b79d754181bbef75515124fa52fbc341a" != gen sum "404ed59b1635e7be0ece41a9dd326675feaa0550"
According to this page https://www.sosoyunpan.com/search?wd...27b3fd1d56971e
there should exist some older full size firmware from 2016: TX7-20160905.img
but I can't find it anywhere to download.
The little more success happened when I used "Amlogic Burn Card Maker" tool which prepared sdcard with the same firmware for flashing.
1. The box started to boot
2. The box led color has changed from red to blue
3. I got a signal on the TV - android logo with progress bar below
4. But after cca 10 secords the progress bar stopped moving and nothing happened for an hour.
What else can I do to unbrick the box?
I would like to try some other compatible firmware via "usb burning tool", but I can't find any other version than "HQYG-TX7-nikodi-20180104.img".
Someone please help...
Originally posted by kostaman View Post
If nobody has the .img firmware version, I don't know what else to try to revive my unresponsive box.
It's not completely dead, because if I boot the SD card made by Card Maker I can see following image on the TV:
https://ibb.co/2SwYncP - I know it' terrible quality photo but there is green android with red circle containing X
I tried to boot CoreElec from SD card (image restored from my old TX7 CE full backup) but it's not booting, no TV signal, just red led light like always...
In USB burning tool it's like this:
Seems like the problem is with DTB partition checksum:
[18:01:14 929][HUB9-1][Inf]--0-7-0-16
[18:01:14 929][HUB9-1][Inf]--CheckFileRunState succeed
[18:01:14 930][HUB9-1][Inf]-- low_power
[18:01:14 935][HUB9-1][Inf]--Send command success
[18:01:14 938][HUB9-1][Inf]--Read command status success
[18:01:14 938][HUB9-1][Inf]-------------Download meson1.dtb-----------
[18:01:14 939][HUB9-1][Inf]--0-7-0-16
[18:01:14 939][HUB9-1][Inf]--Enc(0xadfc318c)
[18:01:14 939][HUB9-1][Inf]-- download mem dtb normal 90112
[18:01:14 939][HUB9-1][Inf]--Send download command success
[18:01:14 952][HUB9-1][Inf]--Read command status success
[18:01:14 965][HUB9-1][Inf]--Transfer complete
[18:01:14 965][HUB9-1][Inf]--Send download get_status command succeed
[18:01:14 969][HUB9-1][Inf]--get_status success
[18:01:15 470][HUB9-1][Inf]-------------ERASE FLASH-----------
[18:01:15 470][HUB9-1][Inf]--disk_initial 3
[18:01:15 470][HUB9-1][Inf]--Send command success
[18:01:15 812][HUB9-1][Inf]--Read command status success
[18:01:15 812][HUB9-1][Inf]-------------Download _aml_dtb.PARTITION-----------
[18:01:15 813][HUB9-1][Inf]--0-7-0-16
[18:01:15 813][HUB9-1][Inf]--download store _aml_dtb normal 90112
[18:01:15 813][HUB9-1][Inf]--Send download command success
[18:01:15 827][HUB9-1][Inf]--Read command status success
[18:01:16 026][HUB9-1][Inf]--Transfer complete
[18:01:16 026][HUB9-1][Inf]--Send download get_status command succeed
[18:01:16 030][HUB9-1][Inf]--get_status success
[18:01:16 030][HUB9-1][Inf]--verify sha1sum 78813f7b79d754181bbef75515124fa52fbc341a
[18:01:16 030][HUB9-1][Inf]--Send verify cmd succeed
[18:01:16 030][HUB9-1][Inf]--ItemSize: 90112
[18:01:16 089][HUB9-1][Err]--failed:Verify Failed with sha1sum, origin sum "78813f7b79d754181bbef75515124fa52fbc341a" != gen sum "404ed59b1635e7be0ece41a9dd326675feaa0550"
[18:01:16 099][HUB9-1][Err]--[0x30405004]UBOOT/Partition _aml_dtb/Verify patition/Error result
[18:01:16 100][HUB9-1][Inf]--Close device handle 0x00000aa0
[18:01:23 044][Global][War]--User click stop button
[18:01:23 045][Global][Inf]--Enable burning 0
[18:01:25 973][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE
Starting to believe it's nand problem... sad because the rest of the device seems to be working, unfortunately CoreElec doesn't boot without reaching to nand.Last edited by blackie333; 28 January 2020, 18:37.
There are currently 2309 users online. 0 members and 2309 guests.
