Anybody else in the same boat here or is it just the one i have?
S7 touchscreen response problems(is it just me....?)
Hi I recently acquired one of these S7's that have been going on sale at big box locations and have zero info out there about them. Not sure if its just a rebranded different model or what but it seems to be a good tablet for 90$ however the screen response is pretty terrible. I'm not sure if this unit is especially worse--like was damaged or has a loose connection but when I try to use Evernote/Papyrus the writing is basically a bunch of dots instead of say the letter "R". The response around the edges seems better and gets worse as you get closer to the center. The problem is with all apps I should mention, trying to drag a tile in scrabble is impossible....it pretty much responds like you are tapping your finger in a line rather than holding and dragging/sliding it.
There are currently 1662 users online. 0 members and 1662 guests.
