Hi Guys & girls.
Today im going to be looking at the new UMIDIGI S2 Pro kindly sent to me from Gearbest
Iv been playing around with the new UMIDIGI S2 Pro over the past week.
Im more than happy with this phone & im realy starting to love it,The device looks awesome with its big 6.0 inch 2160 x 1080 pixels screen.The aspect ratio of the screen is 18:9 and the screen-to-body ratio is of 90%.This phone runs on MediaTek Helio P20- 64-bit octa core processor and is snappy to use but i feel it could be a lot better with out the UMI OS Firmware.
Main Features:
Display: 6.0 inch 2160 x 1080 pixels screen
CPU: Helio P25 Octa Core 2.6GHz
System: Android 7.0
Storage: 6GB RAM + 128GB ROM
Cameras: front 16.0MP + rear 13.0MP + 5.0MP with AF and flash light
Sensors: Accelerometer, Ambient Light Sensor, E-Compass, Gravity Sensor, Proximity Sensor
Features: GPS, A-GPS, Glonass
SIM Card: dual SIM dual standby, 1 Nano SIM card + 1 Nano SIM card or 1 Nano SIM card + 1 TF card
Networks:
GSM: 850/900/1800/1900MHz
WCDMA: 850/900/1900/2100MHz
FDD-LTE: 800/1800/2100/2600MHz
Looks & feel
The phone feels sturdy with its aluminum body. With the 6 inch IPS LCD display, this phone sure does enhance the user’s viewing experience
On the edges of the phone you will find curved corners, as well as the usual buttons and inputs. On the right-hand side is the power key and volume rocker,
On the left hand side there no buttons, Just the sam card tray
On the bottom of the phone is the Type C charging port,Speaker,Microphone
On the rear is the twin camera,Flash light along with the fingerprint sensor
Operating system
The operating system is the latest version of UMI OS which is based on Android 7 Nougat. Some might not like the UMI OS interface but Im starting to like it, it’s smooth and easy to use. But You will notice some bloatware pre installed that can not removed.This i do not like i want to be the one that picks what i have installed on my phone or at lease let me remove the crap that i dont want there.Opening apps does not happen fast and instant most apps take 3 or 4 seconds to load.
Home Screen
Camera & Photos
Auto Focus: Yes
Back-camera: 13.0MP + 5.0MP
Camera type: Triple cameras
Flashlight: Yes
Front camera: 16.0MP
Touch Focus: Yes
Video recording: Yes 4k
Some tech Stuff
The UMIDIGI S2 Pro is splash resistent and seem's to cope well at this (Not tested this my self)
Cpu Z
WIFI (dual band wifi)
GPS
Battery
A good sized 5100Mah Battery That does give you two full day's of usage and that can be fully charged within 3 hours from flat.
NETWORK
2G: GSM 1800MHz,GSM 1900MHz,GSM 850MHz,GSM 900MHz
3G: WCDMA B1 2100MHz,WCDMA B2 1900MHz,WCDMA B5 850MHz,WCDMA B8 900MHz
Network type: FDD-LTE,GSM,WCDMA
WIFI: 802.11a/b/g/n wireless internet
Wireless Connectivity: 3G,4G,Bluetooth,GPS,GSM,WiFi
4G LTE: FDD B1 2100MHz,FDD B20 800MHz,FDD B3 1800MHz,FDD B7 2600MHz
Basic Unboxing Video
Cell Phone: 1
Earphones Adapter: 1
English Manual : 1
Power Adapter: 1
Screen Protector: 1
USB Cable: 1
Rubber protective case: 1
All tests have been done using the stock UMI OS rom (Stay tuned for a look at a pure android 7 rom soon)
Get yours From Gearbest
coupon:GBMBP
