Hi dear , here comes the firmware for GS1_104N0 ! Current version : GS1_104N0 Based on : GS1_101N0/GS1_103N0 USB zip :(update_GS1_104N0.img): later SD card zip : (ota_GS1_104N0.zip): later usb burning tool : https://beelink-my.sharepoint.com/pe...oSJv8&e=jb7TWh Improvement : 1. Sometimes some errors occur to this device when the frame rate is not consistent with HDMI output frequency , such as image trembles often . now you can solve this problems with a method , some tips as follows , Settings->advanced display >(√) Playback auto switch FPS PS : It may get a black screen briefly . 2. Kodi can perform much more better than before . 3. Some shortcuts have been added to remote for popular demands , as the picture shows, ![]() ![]() 4. Google chrome has been reinstalled for you . 5. You could get more wonderful experience on dolby and dts . PS :Now you can update this device from the GS1 101N0 to GS1 103N0 with SD card also . ![]() USB updating : 1. Install the allwinner USB burning tool first 。 2. Click the PhoenixUSBPro.exe in your desktop and run it . 3. Click the upper left button to load the firmware file from your pc ;4. Click the lunch button on this interface . 5. Hold the reset hole and then connect with the computer and tv box , you should keep in mind that the USB2.0 is used for updating but USB3.0 . after that , it is a recognization sign that the red X ( upper right corner)turns green . 6. Finish this updating . SD card updating : 1. copy this file (ota_GS1_101N0.zip) to your TF card or U-disk and then insert the TV box . 2. go in the setting > click the option of "about the media" > choose the first option > choose file > load the ota_GS1_101N0.zip . 3. the systen will recognize this update zip automatically when you run it well and then shut down to go in the update mode , you need to make sure that Power supply must be firmly good enough to finish this updating , power outages would contribute to a failure . you can contact with me if you meet some problems . email : [email protected] / skype : +86 18772960513 |
GS1_104N0 (2G+16G)
GS1_104N0 (2G+16G)
There are currently 1517 users online. 2 members and 1515 guests.
