Anyway, here is a new custom ROM based on the latest firmware available.
This ROM is:
Rooted
Debloated
Init.d Support added
Busybox commands added
Google Play Store Fixes added
Both 3g and wifi only versions
CWM Recovery by Fun
Boot screens by Tattman65
Flash Tool by Finless
Reboot app by Petrus
First Time User's Guide by Pr0xZen
I've also added a couple of new things to the kit. I wouldn't recommend flashing this ROM via CWM initially, but subsequent flashes may be accomplished with a "build your own" CWM flashing template. Just follow the instructions in the readme file in the ClockworkTemplate folder.
I also included the RKBatchTool, in case you need it to assist you in getting into flash mode...or if you want to download and flash the original firmware from Pipo.
Here are the download links:
3G Version
Wifi Version
Enjoy!!!!!
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
