device not found
You seek root?
Make sure USB Debugging is enabled on your K-R42(Settings -> Developer Options)
I hat same issue
tried drivers from lewy then finless rom tools
then spark.. no dice
tried drivers from rockchip.nl
the installed but stil.. no dice
connected usb cable to fully booted cs918
then installed moborobo from same site
and sparks... came alive... 3 reboots later.. root!
installed.. fullscreen
( i'm waiting to upgrade rom.. as there some bug... looking at feedback)
goodluck..Last edited by mitchell4you; 25 August 2013, 13:32.
http://www.freaktab.com/showthread.p...some-USB-ports!
if you have issues with finless rom tool
cheers
There are currently 3277 users online. 1 members and 3276 guests.
