Core: Quad Core CPU: Cortex A53 GPU: Mali-450 RAM Type: DDR3 System: Android 7.1 Processor: Amlogic S905W |
Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA Decoder Format: H.265 Photo Format: BMP,GIF,JPEG,PNG,TIFF Video format: ASF,AVI,DAT,FLV,ISO,MKV,MOV,MPEG,MPG,RM,RMVB,TS,VO B,WMV |
Interface: DC Power Port,HDMI,RJ45,SD Card Slot,SPDIF,USB2.0 Language: English,French,Germany,Italian,Spanish Power Supply: Charge Adapter HDMI Version: 2.0 |
Power Type: External Power Adapter Mode |
Package size (L x W x H): 18.00 x 11.00 x 6.00 cm / 7.09 x 4.33 x 2.36 inches Package weight: 0.3900 kg Product size (L x W x H): 10.00 x 10.00 x 1.60 cm / 3.94 x 3.94 x 0.63 inches Product weight: 0.1200 kg |
Package Contents: 1 x TV Box, 1 x HDMI Cable, 1 x Charger Adapter, 1 x Remote Controller |
Z69 PRO TV Box - Amlogic S905W Android 7.1 2/16GB 2.4G Wi-Fi / Fast Lan
GearbestTags: None
Another Amlogic S905W, add too the ever growing list
Descriptions
Z69 PRO is a TV box, which runs on latest Android 7.1 system. Advanced chip ensures more smooth and flexible operation.
You can enjoy the high-definition images and play large games in your home theater.
Main Features
● Supports 4K x 2K resolution, enjoy super-definition images and breathtaking viewing effect
● H.265 decoding technology saves half of the bandwidth than H.264, so it can show vivid and rich image details
● Large capacity design, allows you to download more applications and games in your TV box
● Amlogic S905W processor is adopted for smooth and flexible operation.
● The latest Android 7.1 system, with open-source application store, you can enjoy whatever you like
● Supports HDMI 2.0 version, convenient to stream your photos, videos to TV screen
The Box, basic as it gets
What's in the Box
Bit of a look around
Remove base
Out with the PCB and Top side
The Bits that make happen, heat sink on good so it can stay
To continue the journey with the Z69 PRO TV Box - Amlogic S905W Android 7.1 2/16GB 2.4G Wi-Fi / Fast Lan
Let's see what we have with this little bundle of Joy today..
Startup ok, Connection to Google account Ok
Many APPs not compatible....at this stage, CPU-Z, Antutu and most other testers...
On to Aptoide for the Downloads
Another not so Nice Rom
Apps orientation not set, no Upper or Lower Bars, need works
The Remote works, has a LED and a KD button, Led shows all Apps was thinking clock
KD I gather is for Kodi not there, we get an unexpected error in log.
Found WiFi and Ethernet to be usable...like most in the range
Clock looks ok deep Blue/indigo
Temps Mid to Hi 70's when Pushed
UI looking a little like a the w95 Beelink, this one one sluggish Needs lots of Luv....or a big HammerLast edited by trebor; 14 February 2018, 01:31.
I feel a good rom would do wonders and make this thing POP , well work well anyway
720 UI as you will see, Must say YT looked good
Many Apps not playing the game, (aptoide will be your friend)
On with the test etc.
Ui and System Information
DRM Info L3
Ram and Storage Truth
Geekbench CPU
More info>>>> http://browser.geekbench.com/v4/cpu/7027298
Geekbench Compute
A1SD Bench
YouTube Playback report
Thanks to Gearbest
There are currently 2338 users online. 0 members and 2338 guests.
