Hi, New official firmware 2.0.7 for Q10/Q5 Pro. Official changelog: New: 1. Support Blu-ray menu, and regain subtitles moving up/down function. 2. Movie Bar support Child Lock function. Only the password is inserted from the left column, the hidden video resources available. 3. Adding add/delete file function for Movie Bar. 4. Adding release time category for Movie Bar. 5. Adding error report function for Movie Bar , and the error will be taken care of within 48 hours. And then the user could delete the data from setting and rescan to check for fixed data. 6. Movie Bar and shortcut of Media Center has been synchronized. 7. Adding 'default subtitle switch' option to subtitle setting menu. When select 'default turn off subtitle' option, video will default close the subtitle, manually switch is available. Otherwise, vice versa. Fixed bugs: 1. Time zone setting not save issue fixed. 2. The main playlist algorithm of the lite blue ray navigation optimized. 3. Got rid of 4096*2160 resolution. 4. When the video is exited from the breaking point, it will start all over again. 5. Kodi unable to play online video issue is fixed. This firmware must be installed over Android 7 firmware 2.0.4 or later. See our forum for full instructions and download: Q10 Pro: http://www.futeko.com/newforum/index.php?topic=2738.0 Q5 Pro: http://www.futeko.com/newforum/index.php?topic=2740.0 Regards, Source: futeko.com |
Tags: None
There are currently 2848 users online. 0 members and 2848 guests.
