FIRMWARE UPDATE FOR UGOOS AM3 ANDROID NOUGAT AND ANDROID MARSHMALLOW
    Changelog 18.01.2018 V.1.1.5 Android 6.0.1
    1. Added LG CEC support
    2. Improved Wi-Fi work
    3. Fixed bootloop when disable Google search app
    4. Improved Media codec playback
    5. Fixed double cursor
    6. Disabled noise reduction
    7. Added application for choosing action on remote control buttons
    8. Fixed SuperSU bootloop, "update binaries" function
    9. Fixes Kodi 17 passthough
    10. Fixes "Adjust display refresh rate" function of Kodi 17
    11. Added CIFS support
    12. Improved samba server
    13. Other changes
    Since now devices get OTA update according to its’ Android version. If you want to change android version, you need to use Full OTA pack for update.
    Download links:
    Marshamallow firmware:
    V 1.1.5 Image
    V 1.1.5 Full OTA pack
    Changelog 18.01.2018 V.2.0.5 Android 7.1.2
    1. Fixed crash in Launcher3 after change language
    2. Fixed focus and scroll bugs in Settings
    3. Changed Enter keycode
    4. Reversed UP and DOWN events in Recent apps window
    5. Fixed Xposed bug after OTA update
    6. Improved work of SuperSU
    7. Fixed GPU problems
    8. Fixed audio volume regulator problem
    9. Added ability to change themes with RC for virtual keyboard
    10. Fixed analog clock of daydream setting
    11. Fixed screen resolution setting crashes
    12. Added HDMI self-adaptation switcher for Media Codec (Playback Settings)
    13. Fixed a screen resolution bug when closing an application, such as Kodi 17+
    14. Local playback improved
    15. Security patches
    16. Fixed black screen after AFR in MX Player
    17. Added application for choosing action on remote control buttons
    18. Many other improvements
    Nougat firmware:
    V 2.0.5 Image
    V 2.0.5 Full OTA pack
    Source:
    https://www.google.com/url?q=http://...Mm3CvO-muZt-hw
    Thanks RD for the Info:
    Hi ,
    i think they used a wrong Date , or they have a Timemaschine and traveled a Year back .
    Nice , but the promised A7 for RK3288 , will it ever come ???
    greetings / gefattern
    • trebor
      trebor commented
      Editing a comment
      No no no this was last years just updated joking
      All fixed
