Mecool bb2 pro firmware request
1º time i put the Superceleron V2 Rom, but i dont like. googlePlay with apps tottaly for SmarTv and i have a problem: pending download...2ºtime i put the Superceleron V1 Rom.and work great i cant detect any problem, thank you SuperCeleron!
i used microSD 8gb and the prog: burn card maker.
may attention for this 4 options
- to partition and format YES
- erase_flash YES [erase in normal]
- erase_bootloaded disable (NO) (VERY important put in dissable)
- Reboot YES
(do you can see how to use this method online... sorry my english)
I don't know if this is of use to you but here is a link to an Android 7.1.2 Russian custom Rom for Mecool BB2 Pro...
LINK: https://translate.google.com/transla...r4&prev=search or
Hope this helps.
Use at your own risk.
Originally posted by DaMeZ View PostHello members does anyone know where I can get the latest firmware please??
There are currently 8352 users online. 1 members and 8351 guests.
