after having bought a t428 and seeing it work for only one day im planing to never buy a product from tronsmart. (eventhough ive been the first here on freaktab to post that tronsmart was releasing that minipc).
well im planning on buying a MK802IV and well, i will be doing some moding too with this mini pc. like a plexiglass case, laptop heatsink adapted to work on the rk3188 chip, some heatsinks for the ram chips and wifi and everything else that it needs. now i`ve sorted out all this but i want an opinion on the psu. im thinking on buying this one: Double Output DC12V 1A and DC5V 4A or this MEANWELL 5V 12V PSU (or smth like this that has both 5 and 12 volts) i want to feed the stick and the usb hub from the same source, dont like to have 2 psu or 3, plus i want to add to the case 1 or 2, 12V silent fans. now im curious when feeding the stick, are used only the red and black wires or the green and white are needed too to tell the stick that is being feed. Im just affraid to damage the stick if i use it by connecting only the red and black wires. sorry for the long post and i hope someone has an answer for this. when i'll have the stick and make the mods ill make another post with photos
thank you
