How To Install ClockworkMod Recovery on MK908
    Hi guys,
    I need some help.
    I read about and i understand is 3 ways to install cwm :
    1.rom manager -didn't work
    2.via Odin - not tested
    3.put to sd cwmod_v08,reebot,install - not working or i did something wrong
    which is best method for my device (tronsmart mk908) ?
    what version of cwm i need ?
    regards,
    Device:Tronsmart MK908 v1,Cozyswan S400
    Rom: Finless Bob v1.6,Stock Rom
    Kernel:Finless Bob v1.6
    CWM-Recovery:by Leolas
    Re: How To Install ClockworkMod Recovery on MK908
    Originally posted by Torkemada View Post
    Hi guys,
    I need some help.
    regards,
    You need the androtab version of cwm made by fun, but is a generic cwm without kernel inside. So if your kernel in the kernel partition fails, you got in trouble, I will add to androtab cwm some kernels for some devices, I will need some betatesters for the devices I don't have. I will need your stock recovery.img if you want to join.
    leolas
    My devices:
    Gearbest.com)
      how can i get it ?
        how can i get it ?
        fun cwm recovery can be obtained in his Web, sorry but I am from tapatalk, look at Google androtab cwm. The stock recovery.img I can obtain it from your stock rom, if you can provide a link to it I will try this weekend.
        leolas
        My devices:
        Gearbest.com)
          stock rom
          this is the link to stock rom: http://download1763.mediafire.com/r7...4za/update.rar
          or :https://github.com/thesawolf/android...ockchip_rk3188
          recovery img :http://www.mediafire.com/?8l1qu17r6iaiygb from Finless
          thank you !
            This weekend I will try it.
            leolas
            My devices:
            Gearbest.com)
              Here's the link to the generic cwm: http://files.androtab.info/rockchip/...ENERIC_CWM.zip
              How to install : http://androtab.info/clockworkmod/rockchip/install/
              Or you can use the RKAndroidTool and select only the recovery.
                Renaming it to update.zip don't work with the recoverys for the rk3188 devices, you need to use any of the other ways
                leolas
                My devices:
                Gearbest.com)
                  Damn, i thought it was gonna work.
                  Gotta sideload it or flash it then.
                    Lets move this to :http://www.freaktab.com/showthread.p...2427#post92427
                    My devices:
                    Gearbest.com)
