MELE H11 Realtek RTD1295 2GB/16GB 4K 3D Blu-ray Navigation Android 6.0 OpenWRT(NAS) Media Player 802.11ac WiFi Gigabit LAN Bluetooth 3.5" SATA HDD Type-C USB3.0 HDMI Dolby Digital Plus Dolby TrueHD
Realtek RTD1295
MELE H11 features a RTD1295 processor, fully supporting Premium 4K UHD contents with a powerful 64bit CPU and Mali-T820 GPU combination in place to handle 4K graphics and offers strikingly realistic pictures. It supports a wider color spectrum (BT.2020) and a 10-bit color, amounting to 1.06 billion colors, instead of the 16 million offered by older 8-bit color technologies, therefore, the gradations between shades and different tones on onscreen content present a far greater degree of realism.
2GB+16GB
2GB DDR3 RAM makes bigger games run smoothly and the utilization of 16GB eMMC memory offers an array of benefits in terms of performance security and reliability, resulting in a richer end-user experience.
Gigabit Ethernet, 802.11ac WiFi & Bluetooth
With the Gigabit Ethernet and 802.11ac dual band WiFi supporting 2.4G and 5G, 5dB double antenna. MELE H11 can provide reliable network access with high data rates. Furthermore, the Bluetooth 4.0 module allows connection to your Bluetooth speakers, keyboard, mouse and many more.
Multi Channels Decoding and Passthrough
Support Dolby Digital Plus and Dolby TrueHD passthrough and downmix. Play everything you want, such as HTML5, MKV, MP4, BD ISO,3D MVC(ISO and MKV), VP9, etc.
HDMI IN
MELE H11 supports HDMI-IN with the Picture in Picture(PIP) function, record function, stream to UDP function. A RTC battery is inside, made it the best solution for Digital Signage.
3.5" SATA HDD & Blu-ray Navigation
Aside from the support for Blu-Ray navigation, it hosts an internal 3.5" SATA HDD Bay for additional storage. A small cutout at the back of the case indicates the existence of an active cooling fan, which makes sense if you’ve got a 3.5" HDD installed.
MEUI 2.0
MEUI is more than a launcher. It is a series of custom components, including a file manager, a NAS kit, a feature-rich player with powerful subtitle supports and OTA service based on the global CDN cloud.
Specification
General | Brand: MELE Model: H11 Type: Media Player Color: Black |
Hardware | OS: Android 6.0 CPU: Realtek RTD1295 64-bit Quad-core A53 GPU: Mali-T820 MP3 RAM: 2GB DDR3 ROM: 16GB eMMC Extended Storage: Support 3.5" SATA HDD(up to 3TB) |
Communication | WiFi: 802.11 ac/b/g/n WiFi (5G/2.4G dual band) Ethernet: 100/1000Mbps(Gigabit LAN) Bluetooth: Bluetooth 4.0 |
Media | Video Resolution: 4K (3840*2160 pixels) , 60fps Video Format: H.265, H.264, MKV, MEPG, BD-ISO, 3D-MVC, VP9, TS, WMV, RMVB, etc. Audio Format: Dolby Digital Plus, Dolby TrueHD, Master Audio |
Interface | 1 x HDMI 2.0 Input(for digital signage, surveillance, recording) 1 x HDMI 2.0 Output(HDR 10bit) 1 x AV Output(3.5mm to 3 RCA) 1 x USB Type-C(USB 3.0 Host/Device) 3 x USB 2.0 Host 1 x Ethernet Port 1 x SD/SDXC Card Slot 1 x Optical Audio Output 1 x 3.5mm Earphone Jack 1 x DC IN |
Other Feature | Cooling/Dissipation: Tiny Fan(40*30mm, sleeve bearing) |
Power | 12V/2A |
Dimensions&Weight | Weight: 2.04kg Size: 255 x 165 x 55mm |
Package Contents | 1 x Media Player 1 x Remote Control 1 x HDMI Cable 1 x Power Adapter(A right power adapter will be sent as your shipping country) 1 x Standard AV Cable 1 x User Manual |
