I immediately installed Finless' 1.5 rom with Leolas' 1080P overclocked kernel. However, bluetooth is very buggy.
Once bluetooth is on - clicking "search devices" accomplishes nothing - you'll get an immediate "no devices found" without an attempt made. However, if you turn bluetooth off and on, if you have a device in discoverable mode - the search will work immediately. That said - pairing has never worked the first time with me. I've tried with a headset, keyboard, generic gamepad (Ipega) and a Sixaxis controller.
The headset's performance was disappointing, plenty of bluetooth lag which was not present with my old Uhost 2. Also - video started to occasionally stutter. The gamepad would only consistently work if I was within 2 feet of the Imito QX1. The sixaxis app would never pair - I suspect because of the search device bug I mention above.
I've only seen one person report a successful use of the Sixaxis App - (H1span1c), but haven't yet seen a reply. If bluetooth has been working well for you, not just Sixaxis, what ROM and Kernel combination are you using? I'd like to try a different ROM to eliminate the possibility of a defective QX1, but I'd rather not do so blindly.
Edit: H1span1c just replied - he was using 720P OC on 1.4a. He'll try Finless 1.5 today.
