D.Bengo X5 Amlogic S905W 1GB RAM 8GB ROM Android 7.1
    Click image for larger version  Name:	15111708626207.jpg Views:	1 Size:	103.6 KB ID:	704373
    Specification
    Model: SRH-X5
    GPU: Mali-450
    System: Android 7.1
    CPU: Amlogic S905W
    RAM: 1G RAM
    RAM Type: DDR3
    ROM: 8G ROM
    Max. Extended Capacity: SD card up to 64GB (not included)
    TV Box Features: Portable
    Decoder Format: H.265,H.264,AVS,HD MPEG4
    Video format: H.265,H.264,1080P,3GP,AVI,MPG,MP4,MOV
    Audio format: MP3,MPEG,DDP,HD
    Photo Format: JPEG,GIF,BMP,PNG,JPG
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: No
    WIFI: 802.11b/g/n
    Power Supply: Charge Adapter
    Interface: OTG,HDMI,USB2.0,AV,Micro USB
    Antenna: Yes
    Language: English,French,Spanish,Portuguese,Russian,Italian, Dutch,Multi-language
    Certificate: CE,RoHs,FCC
    Other Features: Metal Housing
    HDMI Version: 2.0
    Other Functions: PAL,NTSC
    HDMI Function: CEC
    System Bit: 64Bit
    System Activation: Yes
    Power Type: External Power Adapter Mode
    Power Adapter Output: 5V 2A
    Product weight: 0.0750 kg
    Package weight: 0.3500 kg
    Product size (L x W x H): 7.00 x 6.50 x 1.00 cm / 2.76 x 2.56 x 0.39 inches
    Package size (L x W x H): 11.00 x 10.00 x 6.00 cm / 4.33 x 3.94 x 2.36 inches
    Package Contents: 1 x TV Box, 1 x HDMI Cable, 1 x Adapter, 1 x Remote Control, 1 x English User Manual
    Gearbest
    Last edited by trebor; 28 January 2018, 06:51. Reason: 905w chip and No BT at this stage correction
    Thanks to Gearbest today we can have a close look
    Very Small and compact looking unit
    Website mentions 905x in Details but is a 905w, well a chip running at 1.2
    Heat sink is attached goodly
    SRH-X5
    Mali-450
    Android 7.1
    CPU: Amlogic S905w
    1G RAM
    8G ROM
    SD card up to 64GB
    802.11b/g/n
    Metal Housing
    HDMI:2.0
    Power Supply 5V 2A:
    I do see we don't have Ethernet, also see we don't have BT, as this chip appears not to support.
    Lets See what we do have.
    What's in the Box (box has a rough trip not shown)
    Ports and a look around
    Cover off
    Top Side
    Underneath
    Bits that make it happen all happen
    Under side Ram and eMMC
    Topside WiFi and Ram
      To Continue.....
      The Firmware installed is reporting W95 as you will see, same as the Beelink W95 905w
      Has upper/lower Notification and Task bar
      Also has Root access no SU installed, and as mentioned No BT.
      Connection to Google and setup was fair be it a little slow.
      Installed testing Apps OK and some test and Info to follow,
      WiFi was just Fair to OK with it dropping out and a bit of a carry on.
      Appears to work better at Channel 1 Low end as I went higher, Chanel 7 or 12 things got worse
      Be nice if they are going to make it WiFi only give it a decent performance I feel.
      Remote worked OK actually better than I expected.
      As this D-Bengo has 1/8GB Ram it should stream and do the Basics like most other 905w.
      Running a 720 View port, with a 1080 display, things like YT 720 looked Ok
      UI and Installed Apps
      System Info
      Drm Info L3
      Ram and Storage Truth
      CPU-Z
      Display
      A1Sd Bench
      Just a quick look this day
      1/8gb Unit No Ethernet, No BT, Wifi that is Marginal, does a job.
      Gearbest
