Update MK22 Plus / MK22Plus from android 6 to android 7.1 with a SD card
    Update MK22Plus from android 6 to android 7.1 with an SD card
    My problem was => The USB_Burning_Tool gives after 11% an error => [0x00301001]
    Erase bootloader/Switch status/Enum device/Enum error
    This was the solution for me, remember all data is gone after this ( factory reset)
    1 Download the new software MK22PLUS_Android 7.1_170901.img or later
    2 Rename file MK22PLUS_Android 7.1_170901.img to MK22PLUS_Android_7.1_170901.img
    ( replace the space into a underscore )
    3 Download from internet Burn_Card_Maker_V2.0.3 or later
    4 Start => Burn_Card_Maker (see screen shot )
    5 Select the correct SD card ( minimal 2GB )
    6 Formatting Yes (standard)
    7 Open.. the renamed file
    8 Make => SD card
    9 Put the card into the player
    10 Start powerup the player with the reset button pressed in ( 3..5 sec)
    11 The player start to install android 7.1
    Be aware that this action can lead to a defective player, of course yourself are responsible of this action
