question for all h96 users about the remote control
    hey guys i have a t95 box and my question is
    is there any diffrent remote control that turn on your box from complete shut down
    for example my sony tv remote "5" key turns on my box and turn it off
    and becouse i want to use h96 firmware on my box cuz t95 firmwares are bad
    i wanna know if there is any remote that might turn my box on from complete shut down thx
    You mean if the remote, which came with the H96, can start completely powered off Box?
    Mine can. It works fine.
    ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
      Yes i know you can i wonder why my t95 remote turns off my box t95 with h96 firmware but wont power it on
