Change log:
1. Improve WIFI throughput, optimize network speed.
2. Repair blurred image when booting.
3. Unlock Vorke launcher (User Choice can be in the Set -> HOME options select android native launcher to start).
4. Add ROOT switch to Set (set to be restarted to take effect).
5. Add video playback frame rate adaptive switch to Set, off by default.
6. Update Chrome browser to solve the situation which the old version of some websites can not pop up the soft keyboard.
7. Add ariscreen apk, support airplay IOS 11 version, chrome cast and so on. 8. Remove the speed test app and update the KODI software version to 17.6.
Update/Full rom works for Vorke z6/r-tv box s10 3gb ddr4/32gb rom.
Download via support page chooseVORKE-Z6-20171221-PC.zip : http://www.vorke.com/project/support-center-vorke-z6/
Use usb burning tool latest: Usb Burn tool 2.1.2:
https://mega.nz/#!i8pxACKC!EIP9DucLY...7-j3r-NKDBEjFs
Import image after download.
After import select all check marks on burning tool except for reset after complete.
click start
then connect usb to computer or laptop.
then hold in reset pin and plug in usb to android box.
Wait untill complete (100 % burn successful)
unplug usb from android box .
then connect video cable (Hdmi etc)
power cable
remote will only work for Vorke z6 so if using r-tv box you will have to use wireless keyboard dongle etc.
*** Found one issue to fix google sign in download google account manager latest apk.
https://www.apkmirror.com/apk/google...count-manager/then open and install. Fixed
I've contacted there support to let them know to fix issue in next firmware update.
